by JAVYPRO. 12/11/18 11:16 PM
The engine build continues...
by DRTDEVL. 12/11/18 01:54 PM
Which KYB for Gen 1 V6?
by JARED. 12/11/18 01:49 AM
Old Man Emu Lift Installation
by Snowtoy. 12/10/18 10:46 PM
88 Raider KM145 tranny
by DRTDEVL. 12/09/18 02:47 PM
by Bevoman. 12/08/18 08:00 PM
by JARED. 12/08/18 12:07 PM
Tire/Wheel pics
0 registered members (), 96 guests, and 2 spiders.
Topics137,948
Posts1,079,802
Members14,849
Page 1 of 5 1 2 3 4 5
Where can I find an oil filter for a 4D55? #1000725
06/21/10 02:11 AM
06/21/10 02:11 AM
rollguy  Offline OP
So.Cal
I have looked at all the local parts houses and all I can find is a listing for a fram, but the store warehouse is out of stock. The manufacturer is no longer making an oil filter for this truck. I have another oil filter housing from a D50 that takes a smaller filter (available at NAPA), but it was damaged in a collision (I got the engine from the damaged D50 for my Mits). I need to use the larger filter. I have searched this forum, but have only found numbers for the 4D56. Are the filters the same? Any help would be appreciated. Thanks, Rollguy (the Diesel guy)
All Diesel Fleet:
1985 Mitsubishi 2.3 Turbodiesel Pick-up, 1983 GMC Van- 6.2 Diesel.
Benzs: 1995 E300 diesel, 1980 300SD, 1982 300CD, 1983 300D, 1985 190D.
1980 AMC Eagle Limited Wagon powered by: 3.6 Litre I6 VM Turbo Diesel Engine (one of fewer than 10 made, only 2 known to still exist)
Re: Where can I find an oil filter for a 4D55? [Re: rollguy] #1000726
06/22/10 04:58 AM
06/22/10 04:58 AM
rollguy  Offline OP
So.Cal
Update: I tried a NAPA 1067 (4D56 application), and it DOES NOT FIT! It definately takes the Fram PH6353 (or equivalent).
The factory # is: MD069783. There are no auto parts stores locally that stock this filter. Someone please help!
All Diesel Fleet:
Re: Where can I find an oil filter for a 4D55? [Re: rollguy] #1000727
06/23/10 05:49 PM
06/23/10 05:49 PM
hazy_daze  Offline
Athens, Georgia *****
Cross reference jumps from FRAM PH6349 to PH6354. No PH6353. And the Mitsu number doesn't cross.
A suggestion would be to try a NAPA #1324. It's fitment is the 2.3 diesel in the 83-84 Mitsu pickup. It'd be worth a shot. That's all the info I can come up with. Hope that helps!
Re: Where can I find an oil filter for a 4D55? [Re: hazy_daze] #1000728
06/24/10 02:11 AM
06/24/10 02:11 AM
rollguy  Offline OP
So.Cal
I don't know where you got that number from, but on Fram's website this is the info I got for the 193-84 Mitsubishi Diesel:
Part Number PH2921
Product Type Full-Flow Lube Spin-on
Anti-Drain Valve YES
Product Height 5.19"
Product I.D. 20mmx1.5mm Th'd
Product O.D. 3.72"
Relief Valve Setting PSI 12
Style Code 1
Applications Where Used
DODGE TRUCK
D50
4-2.3L Diesel (9) [1983]
4-2.3L Diesel Turbo (J) [1984]
Power Ram 50
Ram 50
FORD
Escort
4-2.0L Diesel (H) [1987-1984]
EXP
4-2.0L Diesel (H) [1987]
Tempo
FORD TRUCK
Ranger
4-2.2L Diesel (P) [1984-1983]
MAZDA TRUCK
B-2200
4-2.2L Diesel [1984-1982]
MERCURY
Lynx
Topaz
MITSUBISHI TRUCK
Pickup
4-2.3L Diesel Turbo [1984-1983]
NISSAN KIZ
N-450
S-2B25
S-2B30
NISSAN KIZ-EXCAVATORS
N-450
S-2B25
S-2B30
PEUGEOT
505
4-2.3L Diesel Turbo [1986]
4-2.5L Diesel Turbo [1987-1985]
4-2.5L Diesel Turbo CAN [1988-1985]
WESTERBEKE
10BTD
12.5 BTDA
15.0 BTDA
WESTERBEKE (Marine)
15 BTDB
38B Four
W33A
WESTERBEKE-GENERATOR SETS
10BTD
12.5 BTDA
15.0 BTDA
Competitor Cross Reference
AC-DELCO PF1789
BALDWIN B7042
BECK/ARNLEY 041-8056
BECK/ARNLEY 041-8061
BECK/ARNLEY 041-8124
BECK/ARNLEY 041-8665
BIG A 92182
CARCARE OF2921
CARCARE OF4826
CARQUEST 85182
CASITE CF2921
CATERPILLAR 1N-4402
CENEX CO2811
CENEX CO2852
CHAMP PH2811
CHAMPION OF418
CHAMPION OF420
CHRYSLER MD013661
CITROEN LS483
CROSLAND 2053
CROSLAND 375
DEFENSE DL4816
DEUTSCH D433
DEUTSCH D571
DEUTSCH PH2811
DEUTSCH PH2852
DONALDSON P550158
FILTERS INCORPORATED OF2921
FLEETGUARD LF3369
FLEETGUARD LF3647
FLEETRITE LFR-83369
FORD E3TZ-6731-C
GRAND PRIX PH2852
GROUP 7 L20253
GROUP 7 L20287
GROUP 7 L34480
HASTINGS LF383
IAPCO A-0216-004
IAPCO A-0248-004
IAPCO OF905
INTERNATIONAL PARTS SERVICES 4-1112
IPD 10065
ITM 11-11102
ITM 11-11201
ITM 111-1201
JIFFY LUBE HL2921
JIFFY LUBE JL253
LAZORLITE L11-1309
LAZORLITE L11-1317
LUBER-FINER PH2811
LUCAS GIRLING F6568
LUCAS GIRLING F6598
MANN & HUMMEL W816/80
MANN & HUMMEL W817/80
MANN & HUMMEL W820
MANN & HUMMEL W840
MASTER PARTS PH-2852
MIGHTY L20287
MIGHTY PH2811
MINIT LUBE PH786
MITSUBISHI MD013661
MOBIL L20253
MOBIL L20287
MOTORCRAFT FL 813
MPA 2113
MPA 2115
MPA 2812
NAPA 1182
NISSAN 438-20005
PEUGEOT 110962
PURFLUX LS520B
PUROLATOR L20253
PUROLATOR L20287
PUROLATOR L34480
QUAKER STATE L20253
QUAKER STATE L20287
QUAKER STATE L34480
QUAKER STATE PO-126
SHELL L20253
SHELL L20287
SHELL L34480
VERA 10-01139
WAKO INDUSTRIAL LO-321K
WAKO INDUSTRIAL LO-823K
WARNER PH2811
WARNER PH2852
WESTERBEKE 35828
WIX 51182
WIX 51324
All Diesel Fleet:
Re: Where can I find an oil filter for a 4D55? [Re: rollguy] #1000729
06/24/10 02:55 AM
06/24/10 02:55 AM
hazy_daze  Offline
Got it from my WIX filter catalog at my NAPA store.
WIX 51182
WIX 51324
If you drop the first number on the WIX, you get the NAPA number. The NAPA filters are WIX in the box. As a matter of fact, there are more WIX filters in NAPA boxes than there are in WIX boxes. We're their largest customer <img src="/forums/images/graemlins/wink.gif" alt="" /> I don't know whether the 1324 will fit or not. You sounded desperate and I thought I would offer that as a possibility. By application, the 1067 IIRC, is the correct filter. But, obviously, if you've tried it and it doesn't fit, then it's not right. Did you check to make sure the filter in the box had the same number printed on it as was printed on the box. Misboxes or mislabels aren't very common, but they do happen on occasion. I've also had them have the wrong threads tapped into them. Again rare, but I've seen it. Have you tried another 1067 to be sure it's not right? Could you have some sort of filter relocater that may require a different filter than what the application calls for? Just throwing out ideas to try to help you figure it out... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Where can I find an oil filter for a 4D55? [Re: hazy_daze] #1000730
06/24/10 03:05 AM
06/24/10 03:05 AM
rollguy  Offline OP
So.Cal
I think the 1324 and 1182 both have 20mm X 1.5 threads, and have the same relief valve psi. The only real difference is the height (5.19"1182, 4.08" 1324). They seem to be for the 4D56, not the 4D55. The filter I need has 30mm threads.
All Diesel Fleet:
Re: Where can I find an oil filter for a 4D55? [Re: rollguy] #1000731
06/24/10 01:32 PM
06/24/10 01:32 PM
PajEvo  Offline
Airdrie, Alberta, Canada *****
That's really strange. The filter cross refs I put in the sticky were originally for 4D55's, but they fit our 56's? <img src="/forums/images/graemlins/confused.gif" alt="" /> Wish I could give you more help...
Re: Where can I find an oil filter for a 4D55? [Re: rollguy] #1000732
06/24/10 02:42 PM
06/24/10 02:42 PM
hazy_daze  Offline
Going by thread size listings for all lube filters in the WIX catalog:
In 30x1.5mm NAPA #1627 height 5.571" OD 4.252" Oring ID 3" OD 3.4". No anti-drain back valve and no by-pass valve.
The other 30x1.5 listed is over 10" long, doubt that's it...
In 30x2.0mm, the listed numbers are 8.43" and 9.145" long, so they're probably not it either.
Re: Where can I find an oil filter for a 4D55? [Re: hazy_daze] #1000733
06/25/10 01:22 AM
06/25/10 01:22 AM
hazy_daze  Offline
Any luck?
I hope by your not posting that you found the right filter and are out joy-riding to celebrate your success <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Where can I find an oil filter for a 4D55? [Re: hazy_daze] #1000734
06/25/10 09:30 AM
06/25/10 09:30 AM
spencevans  Offline
Utah
I have a large stash of the PH6353 filters. They come in a Fram box but they are made by Mitsubishi. If you want one they are $50 each and that includes shipping. Regular price is around $68 per filter. Let me know if your interested. I feel your pain, not only are these things really hard to find, but they cost a small fortune.These filters were only used a trucks equipped with California emmissions and they are much much a larger than the smaller filters used on the federal emmission vehicles. If I remember right they weigh 7lbs each. It's a big freakin filter. If you can't wait a a day or two for shipping, I have one sitting in Glendale at a buddy's shop I can sell ya, but you'd have to pick it up because he does not deliver.
Spence
Spenceevans@yahoo.com
Spence
1985 Mitsubishi PU 2.3 Turbo Diesel, 13" lift, Watercooled turbo, 4D56 Head, Atlas II,Fox Coilovers, Elockers,
1983 Mitsubishi PU 2.5 Turbo Diesel 4x4, fully restored
2003 G500, sliders, beadlocks, roofrack, ladder etc.
Page Time: 0.012s Queries: 16 (0.004s) Memory: 1.0774 MB (Peak: 1.2168 MB) Zlib disabled. Server Time: 2018-12-14 21:26:18 UTC
