by MarkG - 08/10/22 04:39 PM
LED Headlights
The End is Near
LED Headlights
The End is Near
0 registered members (), 59 guests, and 4 spiders.
Topics138,278
Posts1,081,772
Missng Parts! Help Identify #1000976 06/23/10 09:45 AM
topher Offline OP
Hi Folks! I just got a 2nd hand 96' Sporty 4wd last month. Everything seems to be ok until I notice a huge chunk in the engine is missing. Please help out figure out whats missing so I can have it installed. as for the engine, it runs smoothly, no issues with uphill, infact the engine is quite strong. But... the rpm does go up (rarely) without pressing the gas pedal. It goes from 1000 to 3000 even higher if I dont shut the engine down.
1. What is missing? Canister evap? what else?
2. What happens if I dont install them? the engine seems to be ok as of now.
3. Does anyone of you tried to take those things off?
[Linked Image] [Linked Image]
Re: Missng Parts! Help Identify [Re: topher] #1000977 06/29/10 01:06 AM
DennisThompson Offline
I would like to help you but your pics didn't show up on my computer. Does your RPMs go up sitting still or is it when you are rolling at idle. My RPMs will go up as I am rolling down the driveway but goes right back to normal when I stop.
Re: Missng Parts! Help Identify [Re: DennisThompson] #1000978 07/02/10 12:12 PM
topher Offline OP
Hi! I'm sorry if it took me a while to get back. I had so much problem with the car after posting this. So far i've changed the brake master assembly and the throttle position sensor and wiring through the ECU. I guess that solved the RPM issue. But still missing some parts there. I'll post the pics (correctly i hope this time).
Re: Missng Parts! Help Identify [Re: topher] #1000979 07/03/10 05:22 AM
I would imagine from this photo you do not have A/C.
That is where my A/C stuff is at...not that it does anything.....
Re: Missng Parts! Help Identify #1000980 07/03/10 03:53 PM
jaboo5322 Offline
Fuel vapor canister, and purge soelenoids. If it was on that year, that's part of what's missing. My tank rotted out and i put a fuel cell in the back, so i removed mine and everything was fine. But i don't have e-check.
Re: Missng Parts! Help Identify [Re: jaboo5322] #1000981 07/03/10 09:28 PM
Your 96 probably looks more like my 95,
Hope that helps. Dennis
Re: Missng Parts! Help Identify [Re: DennisThompson] #1000982 07/04/10 02:16 AM
topher Offline OP
I would say this is the perfect part that's missing. but what does it do? or what will happen if i dont have this part for a long period of time?
Re: Missng Parts! Help Identify [Re: jaboo5322] #1000983 07/04/10 02:22 AM
topher Offline OP
[quote]Fuel vapor canister, and purge soelenoids. If it was on that year, that's part of what's missing. My tank rotted out and i put a fuel cell in the back, so i removed mine and everything was fine. But i don't have e-check.
How long have you had this removed? did you notice any difference?
Thanks for all your replies! I find this forum very active and people are more knowledgable especially with 4x4s!
Re: Missng Parts! Help Identify [Re: topher] #1000984 07/05/10 07:14 PM
I'm pretty sure they are for emisions, it will probably run ok without them you just may not pass a smog test.
Re: Missng Parts! Help Identify [Re: DennisThompson] #1000985 07/05/10 07:24 PM
Note that he is also missing the EGR system...as tho it were from the factory that way.
PHP: 7.4.30 Page Time: 0.030s Queries: 16 (0.010s) Memory: 2.9207 MB (Peak: 3.1930 MB) Data Comp: Off Server Time: 2022-08-11 14:03:02 UTC
