2 registered members (4x4Wire, Andries_VH),
336
Topics138,075
Posts1,080,454
Members14,973
Most Online678 Dec 8th, 2019
Re: Dok's cure for Jasperitis, aka my 4.3 Swap Thread
[Re: Dok]
#1003710
12/17/10 08:11 PM
I'm planning on keeping the speed sensor so I can retain egr, Jags That Run sells a slick little adapter that plugs into the tcase and allows connnections for the vss and Yota speedo cable. Was going to take the hard but cheap route on the harness but it's not worth it when I can have it modified for 5 wire hookup relatively cheap... somewhere around here I have the JTR TBI swap bible... somewhere..
Brian K. Gallus I have nothing important to say.
[Re: bkg]
#1003711
01/03/11 07:43 PM
22re and trans are sold! Found an r150 and the harness and adapters will be on the way here soon, should be making some real progress here soon...
'87 4-Runner--DD/wheeler, 4.3 swap coming soon '89 Supra--E85 powered 2jz NA-T Swap, 533rwhp 497ft-lbs '89 Festiva, turboed BP swap powered by megasquirt
[Re: Dok]
#1003712
01/28/11 08:58 PM
Reassembly has started! Got all the parts in, will try to put together some detailed info on what all I'm using on the first page of this thread. Harness and PCM came back from Jim's and look awesome, everything is clearly labeled and very clean. Did some tune-up work on the 4.3 last night and got the Speedway 22" chevy radiator mounted: Hoping to spend some quality time in the garage tomorrow to get everything bolted together and possibly in the truck...
[Re: Dok]
#1003713
02/09/11 05:36 PM
Worked most of the day Saturday (after this crazy ice/snow we're having in TX cleared) and go the motor in. Was able to position it so I've got plenty of room up front and the tcase mount bolts right in behind the R150 and adapter. ![[Linked Image]](http://img718.imageshack.us/img718/7779/img20110205144935.jpg) First, out with the IFS Diff (pretty sure it's SAS time now  ) ![[Linked Image]](http://img153.imageshack.us/img153/561/img20110205144845.jpg) Motor ready to go in: ![[Linked Image]](http://img191.imageshack.us/img191/8362/img20110205144921.jpg) Fits better than the 22re did... Little interference between the pan and diff mount (nothing a grinder couldn't fix): Firewall clearance ![[Linked Image]](http://img89.imageshack.us/img89/1258/img20110207162838.jpg) Next up is fitting the radiator and exhaust and figuring out the routing...
[Re: Dok]
#1003714
02/09/11 06:31 PM
Here's my parts/price list thus far: ![[Linked Image]](http://img18.imageshack.us/img18/4822/budgetu.jpg)
[Re: Dok]
#1003715
02/17/11 05:09 AM
Here's my parts/price list thus far: I think I was into my 4.3 for about $4K.... and I didn't have to buy the tranny or adapters. <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> I did have the 4.3 rebuilt/balanced/blueprinted by a local speed shop, though.
