97
guests, and 3
Topics138,179
Posts1,081,008
Brake cleaner and welding-Safety alert
#1005483
08/08/10 06:23 PM
To everyone that uses brake cleaner and welds, please read this. It could save your life and those around you, http://www.brewracingframes.com/id75.htm
"Serenity through Sobriety"
Re: Brake ckeaner and welding-Safety alert
[Re: OOP'S]
#1005484
08/10/10 01:15 AM
This is good to know. Thanks for posting this info!
91 Toy 4x4 V6 85 Toy 4x4 22R
[Re: Bent_85]
#1005485
08/10/10 01:21 AM
Very interesting. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1990 Black Monty LS Over 300K' 1993 Isuzu Rodeo LS 4x4 46k (yes only 46K!)1989 Honda Transalp 600 Africa twin,
[Re: sasnydley]
#1005486
08/10/10 01:31 AM
You can also get chronic bronchitis from burning vinyl floor tile, which is where I got into it. Paid my way thru undergrad school...
[Re: fasteddy]
#1005487
08/10/10 06:24 PM
PHOSGENE!?!? <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
That guy is really lucky even to be alive. That is nasty, nasty stuff <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" />
'89 Dodge Raider -- 3.0L V6, MT, SWB
[Re: OOP'S]
#1005488
08/11/10 01:55 AM
[Re: kewlynx]
#1005489
08/16/10 03:32 AM
Phosgene is also called mustard gas. Burning refrigerant will produce this also.
1985 SR5 4Runner eLocked with Carter Lock 4.7:1 single case Davez Offroad twin stick
[Re: toyrunner]
#1005490
08/16/10 04:36 AM
Tri-cholethelyne is a similar cleaning agent. Navy banned it for shipboard use in the early '70s due to health hazards.
Remember the early Teflon non-stick pan coatings?? And, the special tools needed when cooking with Teflon pans??
When burned, the early Teflon coatings did create phosgene gas.
[Re: 4x4Wire]
#1005491
08/16/10 06:08 AM
When burned, the early Teflon coatings did create phosgene gas. They still will create a gas thats very similar to phosgene. Normal cooking temps with teflon can / will kill your pet birds.
[Re: Kevin C]
#1005492
08/17/10 04:25 AM
trichlorethylene disolves the fat in your body, including some fat you really need, and you die...
Phosgene and mustard gas are two entirely different things, both very nasty...
