Smoking winch
Power steering pump leak.
replace master cylinder
Ignition Coil
Smoking winch
Gen 1 starting issue
by Oso - 04/01/21 05:28 AM
0 registered members (), 123 guests, and 3 spiders.
Topics138,201
Posts1,081,246
What is it worth? #1007847 09/06/10 03:18 AM
Snowtoy Offline OP
No real section to post this, and I figured it would get the most traffic here.
Specs:
4'x8'x2'.
Full boxed metal frame on leaf springs.
Quad lid lifts.
Bike rack holds 4 adult MT. Bikes, and the rear section folds down for ease of loading/unloading bikes.
I built the trailer for my Sister to tow behind her Honda CRV. She no longer needs it, and I have no use for it. The material costs to to build the trailer which does not include the original trailer frame were $300, and a new cheap Chinese frame(4'x8')from Harbor Freight runs $400. Looking for a price range to list it for.
Since pics, I have painted the inside, added a water tight lip, and plan to add front/rear jacks.
Thanks.
Re: What is it worth? [Re: Snowtoy] #1007848 09/06/10 04:27 AM
kewlynx Offline
Jon, you should pick this up for trekking with the XJ.
Do they require homebuilt titles for that kind of stuff down there?
Start with $400.
**ubi apis- ibi salus**
Re: What is it worth? [Re: kewlynx] #1007849 09/06/10 05:55 AM
stony-man Offline
Pretty nice. It would bring a LOT more than 4 around here.
Re: What is it worth? [Re: Snowtoy] #1007850 09/06/10 03:36 PM
lee_raider Offline
It looks like a nice trailer, but it has limited uses since it is a small enclosed trailer. But, for someone who has the use for it, it is probably worth $600-700 I would think. Does it have a title? Some states require titles, and sometimes it is hard to get one for a home-built trailer.
It would make a nice tool box for a small contractor.
Good luck, it looks like a nicely built trailer.
Two MRI's and a CAT scan....it's confirmed. I'm just not right in the head.
Re: What is it worth? [Re: lee_raider] #1007851 09/06/10 09:48 PM
Snowtoy Offline OP
Here in CA all you need to title a trailer is a light inspection. The only time I have had any questions from the DMV is when turning a truck frame and bed into a trailer, then they normally ask to see the original title for the frame. If you don't have one they don't care, I think they ask to make sure it isn't from a stolen truck.
I got the original frame(4'x4') w/a rotten wooden bottom and sides, which the PO used to haul garbage to the dumps so it already had a trailer plate, so no further inspection is needed. I extended the frame about 14" to the rear and 20 to the front, which made it a lot ore stable when towing, it doesn't wander around like it did when I towed it home.
I built another one for a friend of hers from work, and charged $1500(double materials for labor and consumables), and her friend thought they were getting a great deal. However, when having something custom made people often don't mind the price, but since it is a niche trailer I knew it wouldn't sell at that price. I was thinking about $850obo, and see if I get any takers. W/the long Labor Day weekend ending, there is bound to be a few people with small/mid size SUV's like my Sister who could use the extra room when going camping.
Re: What is it worth? [Re: Snowtoy] #1007852 09/07/10 01:12 AM
kewlynx Offline
Where did you pick up the bike racks? I was thinking that might be a viable size for a couple Folbot kayaks inside.
It's ideal for what we do, where we go; thanks for the inspiration. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: What is it worth? [Re: kewlynx] #1007853 09/07/10 03:27 AM
Snowtoy Offline OP
I made the bike racks out of 3/4" and 1/2" galvanized electrical conduit. I like using it for racks(make safari racks with it as well), it is a lot cheaper than aluminum, almost as light, doesn't rust like steel, yet just as strong(for making a rack out of). It welds about the same as any other thin material, but it does create a brighter yellowish light(when you don't grind off the material), than steel, and you have to be a lot more mindful of the fumes. From what I understand, galvanized steel puts off fumes that will/can cause neurological disorders(not permanent)m so you will wan to weld it outdooors. I also run a fan to keep the gasses from moving away from me, even if there is a light breeze.
For something large like a kayak, the 1" conduit might work better for the larger openings you would need to have, and you can still bend it using a manual conduit bender(about $25 for the die, and you need a piece of threaded 1" pipe for the handle). You should be able to put a nice rack together for under $50-100, depending on costs in your area.
Re: What is it worth? [Re: Snowtoy] #1007854 09/07/10 04:31 AM
kewlynx Offline
Nope bikes would still go on top; kayaks in the box:
http://www.folbot.com/design_center/assembly.html
Check the vid
<img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: What is it worth? [Re: kewlynx] #1007855 09/10/10 12:43 AM
Snowtoy Offline OP
That is a nifty design for a packable kayak.
I didn't realize the soft sided kayaks I have scene had folding frames, I thought it was just to make them lighter. I have some friends that have always wanted to take a small boat when wheeling, the two person folding kayak, would be perfect for them.
Re: What is it worth? [Re: Snowtoy] #1007856 09/10/10 05:16 AM
kewlynx Offline
The Alpackaraft is very popular up here on the more remote treks, and I mean *remote*. Good rafts. I've got my eye on a packer's cataraft right now.
Moderated by  4x4Wire, 52degrees, Adam F, Axe Man, kewlynx
PHP: 7.2.34 Page Time: 0.030s Queries: 15 (0.009s) Memory: 2.8728 MB (Peak: 3.1634 MB) Data Comp: Off Server Time: 2021-04-13 01:44:28 UTC
