177
Topics138,201
Posts1,081,246
Re: 4D56 into Mazda B2600i swap thread
[Re: redbull]
#1015581
06/07/11 03:07 PM
I'll be taking more pictures soon, what do you want to see that you can't see in the ones on the first page? Do you mean hanging off the back of the alternator or bottom? The thing on the back is indeed a vacume pump.
[Re: JeffatTireBalls]
#1015582
07/06/11 11:52 PM
The engine is sitting in the bay and bolted to the bellhousing. Now to fab up some motor mount brackets when I get back from vacation. ![[Linked Image]](http://cdalejef.smugmug.com/Trucks/Mazda-B2600i/i-LSg5ZHF/0/L/smugshot6352822-L.jpg) ![[Linked Image]](http://cdalejef.smugmug.com/Trucks/Mazda-B2600i/i-hZ6fTVW/0/L/smugshot450902-L.jpg)
#1015584
07/24/11 02:58 AM
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Looking good!
87 Raider 4D56td v5MT1 31's..Basically Stock
#1015585
07/31/11 02:21 AM
man if I could only win the lotto , this would be the 1st thing I'd do! <img src="/forums/images/graemlins/kewl.gif" alt="" />
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: KrzyDav]
#1015586
08/02/11 03:31 PM
Got the truck back from the exhaust shop, had them run 2.5" with no muffler. Drove it to work this morning (20 miles) and it did great. After I get a couple hundred miles on it, install boost and pyrometer guages I'll do some tweaking with the fuel screw and wategate to get a tad bit more fuel into the system. After that I'll start looking into installing an intercooler. Funny thing is, it will only run with the vacume hose disconnected from the EGR. When I have it connected it is exteremly hard to start and runs like crap and smokes badly once it does start. With the vacume hose disconnect, it starts and runs great. <img src="/forums/images/graemlins/confused.gif" alt="" />
#1015587
08/23/11 01:12 PM
I've drove this truck to work and back 30 miles round trip everyday and two 250 mile road trips in the last month and its running great. Averaging 28mpg and cruises nicely at 70mph. The power is much better than the gas motor pulling hills in 5th that I used to have to downshift to 4th for. I have the max boost set at 9psi till the motor gets a few thousand miles on it. After that I'll be installing an intercooler, pyrometer and turning up the boost and fuel. <img src="/forums/images/graemlins/smile.gif" alt="" />
#1015588
09/28/11 09:02 PM
More goodies... A-pillar guage pod with pyrometer and boost guage... Dash Gauges from a Montero... ![[Linked Image]](http://cdalejef.smugmug.com/Trucks/Mazda-B2600i/i-qgfbFpg/0/M/smugshot7937146-M.jpg) Magellan iPhone mount... ![[Linked Image]](http://cdalejef.smugmug.com/Trucks/Mazda-B2600i/i-JLS3GdC/0/M/smugshot3729337-M.jpg) Center console from a Ranger. I found a spray paint that matched my interior for the plastic parts but I still have to get the armrest recovered. ![[Linked Image]](http://cdalejef.smugmug.com/Trucks/Mazda-B2600i/i-GQbrcd5/0/M/smugshot5024438-M.jpg) And just so there's no confusion... ![[Linked Image]](http://cdalejef.smugmug.com/Trucks/Mazda-B2600i/i-SmVwfZH/0/M/smugshot3947242-M.jpg)
#1015589
05/09/14 09:35 PM
#1015590
05/11/14 10:00 PM
That's one beautiful Mazda and with the pimpin' red interior. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[SOLD] 1996 Pajero 2.5 TDI on silly big 38" tires and 14" wide rims. Stock rear locker, 50mm body lift, 1" rear axle shift. [CURRENT] 1984 Ford E250,6.2 GM diesel, TH400, NP203/205 doubler,D44 front with ARB,D60 FF rear with no-spin,HID lights, VHF, GPS, Onboard air. 44" tires.
