Windshield removal/install ?
Gen 1 rear locker ?
Mass Airflow unit questions.
Relay under console !
0 registered members (), 112 guests, and 4 spiders.
Topics138,147
Posts1,080,839
Members15,113
engine swap #1018189 01/14/11 04:33 PM
bingocouple Offline OP
do you guys know if a 2.7 v-6 kia motor will fit into the 2000 sporty? I am waiting for a response from a guy with all the measurements to see if there is room. I would also like to know if I can use the same tranny or if I would have to get one specific to that engine.
Re: engine swap [Re: bingocouple] #1018190 01/14/11 08:52 PM
logansportage Offline
Interesting thought. I'd love to have the 2.7 or for that matter the 3.5 from the Sorento, but I don't think there is enough room side to side. It's really cramped with the 2.0 inline 4 now. I know there was a guy that fitted an LS1 engine into a Sorento, but they have a lot more room and he ended up doing some extensive trimming and clearancing to get it to fit. For an engine swap like this you are better off using the trany that comes with the engine. It's already designed to work/fit to the engine and you only need to fit it into the space you have.
Re: engine swap [Re: logansportage] #1018191 01/15/11 10:30 AM
DamKia Offline
Kia Moderator
Both of them are derived from Mitsubishi engines so there may be some issues with the bellhousing and clutches.
The easy way if you wanted to do a full swap would be with a 2.7l 4 cyl Toyota motor (IIRC a 3RZ) that fits onto a transmission and tcase that drops to our side (right hand drop), although I don't know about overall length vs our overall length.
Anything related to Mitsubishi generally is a left hand drop if you also use their transmissions and tcase.
Re: engine swap [Re: DamKia] #1018192 01/15/11 03:32 PM
ok thank you. It was just and idea.
I took a 231 v6 and put it in a suzuki samurai once. Worked great, tons of power, could get the front tires off the ground in 1st gear.
Re: engine swap [Re: bingocouple] #1018193 01/15/11 06:33 PM
fokion Offline
there are RUMORS that a ford v6 2.5cc can be fitted. Buto sorry no other info.
Have in mind thow that a HiTech management-wise engine will require ALL sensors ECU harnes e.t.c to work.
Plus the fact that the sportage 2.7 in a west to east orientation instead a north to south like ours
there is also in Korea a street car that haw two engines
Ours and a 2.5 V6 that could in theory, matchin our bellhousing
And I know because a friend that imports used engines an other KIA parts from Korea, is giving its engines for the sportages.
Unfortunately I dont remember the name of the KIA street model..
Re: engine swap [Re: fokion] #1018194 01/15/11 06:45 PM
fokion Offline
Re: engine swap [Re: fokion] #1018195 01/15/11 07:29 PM
DamKia Offline
Kia Moderator
Also Mazda derived. Same FE motor as us
MAZDA LUCE 5gen
MAZDA 929 3gen
Or the 2.5 liter
Engine manufacturer:
Kia K5 (variant of Rover KV6)
Engine type:
spark-ignition 4-stroke
Fuel type:
petrol (gasoline)
Fuel system:
indirect injection
Charge system:
naturally aspirated
Valves per cylinder:
4
Valves timing:
Additional features:
Multi-point fuel injection
Noting that this is not the 2.5 liter Mazda motor AFAIK
DOHC Mazda 2.5
Re: engine swap [Re: bingocouple] #1018196 01/16/11 07:10 PM
DennisThompson Offline
There is a Sportage on youtube with a Chevy 454, it all depends on how much money and/or how much work your willing to do on what engine swap you want to do. Almost any swap is posible but is it worth it?
A few question you need to find out.
1. Will it bolt up to your trans? NO.
2. Can you use the 2.7 trans? No, it's in there sideways.
3. Is there a rear wheel drive Mitubishi trans and t-case that bolts up to the 2.7? Maybe.
4. Is the front output on the right side for the Kia front axle? Maybe.
Do some research and decide if it's worth it to you, if I was going to all the trouble on an engine swap I would do a 302 Ford, if they fit in a Miata I could get one to fit in a Sporty, all it takes it money.
Re: engine swap [Re: DennisThompson] #1018197 01/19/11 03:39 AM
DEFBOY35 Offline
lol about the miata fitment. i have had that exact same thought about the 5.0 myself.
reasonably compact and huge power potential.
i myself have thought about going to a toyota transmission bolted to a 3.4 v6
for what it all would be worth in the long run and $to pwer ratio, i think it would be the better option than trying to do the stroker conversion to my fe.
Re: engine swap [Re: DEFBOY35] #1018198 01/19/11 07:37 AM
fokion Offline
Also in Grecce there are a couple of sportages with 2.0 cosworth ( ford sierra ) turbo engines with 400++Hp used for.....
"night" racing.. <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
PHP: 7.2.34 Page Time: 0.031s Queries: 15 (0.009s) Memory: 2.8695 MB (Peak: 3.1634 MB) Data Comp: Off Server Time: 2020-10-30 07:26:40 UTC
