Starter motor are they serviceable ..
by rxinhed. 04/17/18 03:14 AM
Considering Part-Out...
by rxinhed. 04/12/18 12:34 AM
by rascott. 04/11/18 08:44 AM
1999 Montero Sport Limited 3.5L crawler build
by ES_97Sport. 04/11/18 12:56 AM
by JeffatTireBalls. 04/08/18 02:57 PM
87Monty will have a 4BT
by JeffatTireBalls. 04/08/18 02:50 PM
Tuning up 4D56T
by red1987raider. 04/02/18 12:41 AM
by 4runnernomore. 04/16/18 01:49 PM
by DRTDEVL. 04/06/18 02:04 PM
Tuning up 4D56T
R&P Contact Pattern
by JeeperDan. 03/15/18 01:14 PM
by rxinhed. 05/01/16 12:11 AM
My '88
4x4Wire YJ
0 registered members (), 45 guests, and 5 spiders.
Topics137,824
Posts1,079,359
Members14,753
Page 78 of 150 1 2 76 77 78 79 80 149 150
Re: PR0NOCAM [Re: Lloyd Swartz] #1024438
10/21/12 10:20 PM
10/21/12 10:20 PM
ClayTK  Offline
Gilbert, AZ
"exhaust smells good" That aint no bong you know!
hehehe
1998 Mitsubishi Montero
2" Body lift
35" Cooper tires
Parrot Asteroid Smart w/ factory AMP
Cobra 29 LX CB Radio w/ Firestik MK-DM18R rooftop mount
Aisin Manual hubs
Grote 36 LED, TractorPlus (Wired to factory fog light switch)
Speedo [Re: ClayTK] #1024439
10/22/12 05:37 AM
10/22/12 05:37 AM
lordtrunks  Offline
Apache Jct, Arizona,USA *****
I need this to make the speedometer to work
http://www.dakotadigital.com/index.cfm/p...prod/prd126.htm
They just came out with a gps unit that sounds pretty awsome but the price is about $100 more.
http://www.dakotadigital.com/index.cfm/p...prod/prd837.htm
SO pick either one lloyd and i'll get it in, if you want the speedo to read correct when in low range the gps version will be the way to go reason being is i can't get the speedo pulse signal off the transfer cause since its a jk t\case it doesn't have a speedo gear so i have to get the signal from the transmission tail shaft before the t\case so high range will be fine but in low its gonna read very fast.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Speedo [Re: lordtrunks] #1024440
10/22/12 02:49 PM
10/22/12 02:49 PM
Lloyd Swartz  Offline
Albuquerque NM US
GPS will be the way to go then. I will get that ordered soon for you.
Re: Speedo [Re: Lloyd Swartz] #1024441
10/22/12 04:44 PM
10/22/12 04:44 PM
TOASTY  Offline OP
Mesa AZ, US. *****
Wow! Finally, looks like i'll be going the GPS interface route as well. not a bad price either for what it is.
1999 Montero Blizzard package
2005 Montero Limited
2015 Mirage with antifreeze Sparco wheel package
Re: Speedo [Re: TOASTY] #1024442
10/22/12 05:42 PM
10/22/12 05:42 PM
wrenchwench  Offline
Phoenix
GPS is neat and all but why does it matter what your speedo says in 4L ?
Re: Speedo [Re: wrenchwench] #1024443
10/22/12 06:00 PM
10/22/12 06:00 PM
TOASTY  Offline OP
Mesa AZ, US. *****
I don't care what mine says in 4 Low or 4 low low, i like it more for the ability to run what ever tire and gear ratio i want without recalibrating my speedo. So if i were to get some skinny A/T 33's for the street and 37's for fo' wheeling it would be cool.
Re: Speedo [Re: wrenchwench] #1024444
10/22/12 07:01 PM
10/22/12 07:01 PM
lordtrunks  Offline
darn right toasty if you want you can ditch the mitsu compass and hook one of their compass gauges and not have to drive around in circles to get it to work, to bad they don't have a separate gauge for the altimeter function yet.
Re: Speedo [Re: lordtrunks] #1024445
10/22/12 11:06 PM
10/22/12 11:06 PM
Albuquerque NM US
I actually do like to know my speed in 4 Low, gives me an idea how much ground we are covering and whether we will make my ideal camp spot.(usually not <img src="/forums/images/graemlins/lol.gif" alt="" />) GPS Unit can do that as well, but may not be as consistantly convenient. Regardless speedo would have been off with 37's by a long shot. I think my rig has the Altimeter <img src="/forums/images/graemlins/kewl.gif" alt="" />
It is amazing all the cool gizmos cars have now that would be so handy off-road, average speed, fuel economy, distance to empty......Not sure about automatic brakes when something is too close though <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Crown King would be a good test for Gears, Cooling, Rattles, Flex Issues.....With out scratching my rig <img src="/forums/images/graemlins/shame.gif" alt="" /> Not sure if you want to wait for gears and front locker install, or test everything on the rolling chasis so far? Proably should get the other skids on as well.
Are we about ready to start a checklist of some sort? Once gears/ locker are in we should plan a pick up weekend to do a real shakedown and work on any loose ends.
Re: Speedo [Re: Lloyd Swartz] #1024446
10/23/12 01:38 AM
10/23/12 01:38 AM
PA_JERO  Offline
Gilbert, AZ
Doing a shake down before hand would be good just to make sure of how it rides handles before we do gearing. As far as a check list, we should start getting an idea of what we need to get done before it sets sail. I still have the spacers in a box here but that will be last. It won't fit in my garage if we put those on <img src="/forums/images/graemlins/smile.gif" alt="" />.
!!!!!!!!!!!!!WHAT ABOUT BOB!!!!!!!!!!!!!!!
Re: Speedo [Re: PA_JERO] #1024447
10/23/12 07:47 AM
10/23/12 07:47 AM
ClayTK  Offline
Gilbert, AZ
In regards to the GPS speedometer... Well sometimes it might be difficult to get enough satellites to give an accurate reading, GPS always has a margin of error regardless of device. So it probably won't be accurate all the time I am sure.
But its an awesome adaptation for sure <img src="/forums/images/graemlins/kewl.gif" alt="" />
2" Body lift
35" Cooper tires
Aisin Manual hubs
Moderated by  4x4Wire, TOASTY
Page Time: 0.032s Queries: 16 (0.022s) Memory: 1.0800 MB (Peak: 1.2192 MB) Zlib disabled. Server Time: 2018-04-21 19:19:49 UTC
