Gen 1 rear locker ?
Mass Airflow unit questions.
Relay under console !
Topics138,146
Posts1,080,836
Members15,113
Page 2 of 2 1 2
Re: 97 sporty with front rear locker lifted [Re: jenssporty4x4] #1025407 03/28/11 04:17 AM
H
hadtomer Offline
the turbo set up looks sweet. how much boost are u running? did u lower the compression?
Re: 97 sporty with front rear locker lifted [Re: jenssporty4x4] #1025408 03/28/11 08:54 AM
freddiespyker Offline
hi jen
can you maybe tell me if you got a part number for the lsd you installed.it will help me alot here in south africa
regards
freddie
Re: 97 sporty with front rear locker lifted [Re: freddiespyker] #1025409 03/28/11 08:38 PM
jenssporty4x4 Offline OP
i didn't wright the part number down sorry but i got more info that might help out.
Re: 97 sporty with front rear locker lifted [Re: jenssporty4x4] #1025410 03/29/11 07:51 AM
hi thx for the info you have posted so far.i did some phoning around here in south africa it looks to me that for some reason that model of mazda is very rare here by us i also went the ebuy way but it is gonne cost me alot of money to get it from there in our currency it is about 3000 south african rands excluding shipping.but i will keep on looking around for it.oooooooooo your kia is it automatic like mine or manual? <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 97 sporty with front rear locker lifted [Re: freddiespyker] #1025411 03/29/11 10:39 PM
its a 5 speed with a stage 3 6-puck clutch
Re: 97 sporty with front rear locker lifted [Re: jenssporty4x4] #1025412 03/30/11 12:46 AM
How many Horses you pushin out now with all that?
Have you had any issues with the 3 stage clutch at all?
This is quite the rig you have built up.
To bad it isn't a 2001 then I would be doing everything you did!
Re: 97 sporty with front rear locker lifted [Re: jenssporty4x4] #1025413 03/30/11 03:31 AM
logansportage Offline
Jen,
Thanks for the info on your Sportage and the front LSD you are using. As soon as I can find one I'm going to put it in. I'd like to have the gear type instead of the clutch, but something is better than nothing. Do you have a P/N on the clutch you used? I need to put in a clutch and would love any info you have and observations so I can compare it to others.
Re: 97 sporty with front rear locker lifted [Re: logansportage] #1025414 04/04/11 01:15 AM
DEFBOY35 Offline
definitely want to know more info on the turbo set up including any ecm mods and sensor mods etc.
as for the people that the info on the lsd's would help, would there not be a way to adjust the lsd as to when it would activate? a good question for a driveline shop perhaps.
Re: info for the lsd 97 sporty with front rear lsd locker lifted [Re: jenssporty4x4] #1025415 01/05/12 05:41 AM
Peabody Offline
<img src="/forums/images/graemlins/zombie.gif" alt="" /> WARNING <img src="/forums/images/graemlins/zombie.gif" alt="" /> WARNING <img src="/forums/images/graemlins/zombie.gif" alt="" /> WARNING <img src="/forums/images/graemlins/zombie.gif" alt="" /> WARNING <img src="/forums/images/graemlins/zombie.gif" alt="" /> WARNING <img src="/forums/images/graemlins/zombie.gif" alt="" /> WARNING <img src="/forums/images/graemlins/zombie.gif" alt="" /> WARNING <img src="/forums/images/graemlins/zombie.gif" alt="" /> WARNING <img src="/forums/images/graemlins/zombie.gif" alt="" /> WARNING <img src="/forums/images/graemlins/zombie.gif" alt="" /> WARNING <img src="/forums/images/graemlins/zombie.gif" alt="" />
To anyone who reads this thread and gets the impression that the Mazda LSDs for the non-turbo RX-7 or Miata (both with 7" ring gear) will fit in BOTH the FRONT and REAR carriers of the '95-'97 sportages, THIS IS ABSOLUTELY FALSE. I have pulled the parts and done the comparisons, to include the fitment of an OBX LSD spec'd for the '94-'05 Miata. These differentials will fit in the front carrier. THEY WILL NOT FIT THE REAR - unless you can figure out how to set up the rear carrier with a 7" ring and pinion (the pinion, carrier bearings and spacing are the same: only the diameter of the ring gear and ring gear mount differ in the rear, that being 7.5", vice the 7" found in the front end). But reducing the ring gear diameter does not make for a stronger rear differential...
After reading this and other threads, I was mislead to believe there was compatibility - that the 7.5" ring gear would mount. It will not. See for yourself...
Let the myth be dispelled... forever!!! <img src="/forums/images/graemlins/angry.gif" alt="" />
all work welded done by me jennifer..look i know its not a full locker but its better than a open diff and will get you just as far as most trucks and not get stuck for the most part. the kia sportage can have some kind of better trackion now... with lsd..
the front is a lsd off the RX7 87 2nd gen with big axle
rear is the same. they both fit front and rear of the 97 sporty.
the rx7 has 2 axle types for the 1st and 2nd gen 1 is the smaller axle this is the 1st gen rx7 this don't fit.. the other is the larger one this is the 2nd gen rx7 that fits the 95-97 sporty's not sure on other year sporty's if its the same 3rd member im sure it will fit as well
remember depends on the year of sporty as well this will fit that i know 95-97 kia sportage 2.0 dohc and sohc
there are tons of locker types LSD's for the RX7 on ebay
Mazda RX-7 LSD (Late - '86-88 gxl)
here is the fit:::
86-88 gxl RX7 and miata non turbo
N/A limited Slips = 7" ring gear this one fits the sporty
86 Sport - clutch type
86-88 GXL non turbo - Clutch type <--------- fits kia sportage
88 GTU - Clutch type
89-90 GTUs - Viscous type
KAAZ and Mazdaspeed also have nice lsd's and some ebay ones THE UNIT WILL ALLOW FULL LOCK OF BOTH REAR WHEELS WHEN THROTTLE IS ON AND OFF
All turbos came with a limited slip but 8" ring gear will not fit the kia sporty.
the 7" ring gear fit perfect same size axle spline and bearings and all bolts in put your gear on and set back lash then ur done ready to go..
if you want to see the lsd in action ill post a vid here and youtube were going out to browns camp sat.. for mud and rocks to test out. the 4x4
Re: info for the lsd 97 sporty with front rear lsd locker lifted [Re: Peabody] #1025416 01/08/12 10:24 PM
DennisThompson Offline
See, I'm not crazy! I did a lot of research on that years ago and all the posts made me start to doubt what I read, thanks for the info, it could save someone lots of time and money.
Page 2 of 2 1 2
PHP: 7.2.34 Page Time: 0.031s Queries: 16 (0.009s) Memory: 2.9002 MB (Peak: 3.1636 MB) Data Comp: Off Server Time: 2020-10-25 23:24:00 UTC
