Introduction & New Raider
by Bigshankhank. 01/21/19 07:04 PM
My first Raider
by ATTILA. 01/13/19 01:29 PM
by tdf46. 01/12/19 12:15 AM
by tdf46. 01/12/19 12:12 AM
2nd Gen Front Lincoln Locker.
by RockDoc. 01/12/19 10:31 PM
My first Raider
by Flicky8. 01/12/19 03:28 AM
by tdf46. 01/09/19 03:56 AM
0 registered members (), 128 guests, and 1 spider.
Topics137,963
Posts1,079,874
Members14,875
Page 5 of 5 1 2 3 4 5
Re: Gen1 Transfer Cases Options [Re: RECON45] #1026891
03/02/12 07:09 PM
03/02/12 07:09 PM
LandRaider  Offline
Ocean Springs, MS *****
on my 231 I hacked the handle off the shifter, and welded on a chromed steel rod that was bent like I needed it to be. I slotted the floorboard with a jigsaw, and then used some rubber matting with a slit in it to work as the floor seal. Then I got a K5Blazer Boot, and used it to cut out a ring, and screwed that all to the floor.
87 Raider 4D56td v5MT1
31's..Basically Stock
Re: Gen1 Transfer Cases Options [Re: LandRaider] #1026892
03/02/12 07:11 PM
03/02/12 07:11 PM
LandRaider  Offline
Here's a pic. Notice the location... This is with a 700r4, and GM motor, so it has little bearing on where yours would need to go.
http://alliedpaper.org/landraider/SASpics%20%2812%29.JPG
LARGE picture
Re: Gen1 Transfer Cases Options [Re: LandRaider] #1026893
03/02/12 08:01 PM
03/02/12 08:01 PM
RECON45  Offline OP
Statesville, NC
Very clean. If I had carpeting for mine, I might would consider that route. I think I got most everything figured out now. it is now a matter of having a few clear weather days to work on it to get everything swaped. Thanks for the input and picture.
Re: Gen1 Transfer Cases Options [Re: RECON45] #1026894
03/06/12 09:34 PM
03/06/12 09:34 PM
RECON45  Offline OP
Statesville, NC
I will try to get pictures but I have a mcmaster carr shifter and 6' cable to use for my shifting. i need to fab a bracket for the shifter to hold it to the floor and a bracket for the cable part to the Tcase. there really is much of a place to set up a bracket that bolts up to the tcase. i will try to get pictures. I want to see if I can use the factory shifter knob on the new set up. i might have to mod it a little bit.
Re: Gen1 Transfer Cases Options [Re: RECON45] #1026895
03/07/12 03:03 AM
03/07/12 03:03 AM
Mudraider  Offline
Orange Park, FL
I got my Dana 300. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Gen1 Transfer Cases Options [Re: Mudraider] #1026896
06/05/12 10:20 PM
06/05/12 10:20 PM
dsmguy  Offline
Texas
the 4cyl raider transfercase and upgrade for the mighty max? the only thing i see different is that is has the nuetral position and mine does not.
89 Raider V6 5 speed factory lsd rear
88 mighty max 4 cyl. 5 speed
Re: Gen1 Transfer Cases Options [Re: RECON45] #1104154
02/03/18 04:31 AM
02/03/18 04:31 AM
djacidjac  Offline
PA USA
I'm exploring options. I was hoping to fit some kind of under-drive box like the BlackBox from NorthWest Fabworks. I've been googling for a couple of hours and all I can find is some vague "23 spline" talk.
Does anybody know for sure what are the shaft specs on a gen 1, 2.6, manual KM-145 transmission:
1. transmission output shaft
a. diameter
b. spline count
c. usable/spline length
2. transfer case
a. (will be same as above)
b. (will be same as above)
c. usable/spline depth
3. any other info related (such as what adapters or cases have the same bolt pattern, what model name/number the transfer case is, etc)
OBA (stock AC compressor)
Re: Gen1 Transfer Cases Options [Re: RECON45] #1104164
02/03/18 06:50 PM
02/03/18 06:50 PM
rxinhed  Offline
Gerber, CA *****
Mark's in Australia sell a 2.85 low gear set. They've had 3.15 in the past. Look up Toasty or Josh on Adventure Driven Design (.com), as I believe they're marketing the kits.
1980 Power Wagon W400
Page Time: 0.013s Queries: 16 (0.005s) Memory: 1.0922 MB (Peak: 1.2176 MB) Zlib disabled. Server Time: 2019-01-22 02:54:13 UTC
