97
Posts1,080,940
Re: Allochris Camper Travel Update from Smithers w/ blowing headgasket problem!!!
[Re: kewlynx]
#1026949
06/04/11 06:31 AM
That's awesome, given you're about ready for summer work, yes?
Sounds like that might work out for ya Chris. <img src="/forums/images/graemlins/cheers.gif" alt="" /> ya, wow. work has been taken over my life i just got my 1st day off today since i updated last! I haven`t got the chance to price at engbldr yet, but I should though...
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/ Camper/33x10.5BFG-AT/Open 4:88/1.5"BJS/ +2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
[Re: allochris]
#1026950
06/07/11 12:36 PM
I purchased the entire top end kit including new head from engblr. Head was built to match my gears, tire size and the type of driving, on and off road concidered. I'm completely satisfied with the work. All the lower end stuff was done locally and price was competitve. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: chpfx]
#1026951
06/08/11 07:57 AM
You will be so happy, did you get a new cam also?
I used a rebuilt head with can and headers and it made a big difference. I later went with the after market head from engblr and that made a huge difference.
Good luck and keep us posted.
Ralph
Ralph
1991 Toyota 4x4 Standard Cab Pickup. engnbldr cam and head. Doug Thorley Headers Home Made Cat Backs 30x9.5x15 BF Goodrich All-Terrain M/T KM2
[Re: Ralph]
#1026952
07/20/11 02:54 AM
Hi i'm back online after 2 months working in the bush. So yes, i picked up the rebuilt 22re from langley for $1200 but there is one thing that I need to confirm.
The mechanic (rebuilder) says that new head bolts are not needed. But I've heard conflicting info b/c of the stretch to yield design of the head bolts.
So before i drop it in my truck, can I simply unbolts the current bolts & put in new ones, w/o screwing up the headgasket & head/block placement?
Should I do remove & tighten (but not torque to spec.) one bolt at a time to avoid change in headgasket compression pressure?
If I do need to take the timing cover off, should I also change the plastic guide out & put in a metal one instead?
[Re: allochris]
#1026953
08/24/11 03:04 PM
[Re: allochris]
#1026954
08/24/11 03:07 PM
Today's progress! Ready for removal: ![[Linked Image]](http://i92.photobucket.com/albums/l37/allochris/th_DSCF6291.jpg) Out she goes: ![[Linked Image]](http://i92.photobucket.com/albums/l37/allochris/th_DSCF6294.jpg) Empty bay: ![[Linked Image]](http://i92.photobucket.com/albums/l37/allochris/th_DSCF6295.jpg) New rebuilt engine all dressed up: ![[Linked Image]](http://i92.photobucket.com/albums/l37/allochris/th_DSCF6297.jpg) In she goes: ![[Linked Image]](http://i92.photobucket.com/albums/l37/allochris/th_DSCF6299.jpg) Reassembly: ![[Linked Image]](http://i92.photobucket.com/albums/l37/allochris/th_DSCF6300.jpg)
[Re: allochris]
#1026955
08/25/11 05:25 PM
All fixed! ![[Linked Image]](http://i92.photobucket.com/albums/l37/allochris/th_DSCF6301.jpg) Just need to break-in 500km now + hot valve adjustment. It idles dead-on upon initial startup. Question: -Is the valve cover gasket re-useable? Silicon needed? -What's the valve clearance setting at hot?
[Re: allochris]
#1026956
08/26/11 01:47 AM
nice job there brutha ..
hot I generally adjust to 8 and 12(some use 7 and 11 , but who really has those feelers) .. depending on if the rockers and adjust screws and valve tip grind are new or not ? may need adjusting again if new .
valve cover gaskets are reusable , just be sure they are clean and debris free , and be sure to use a little "dab" of silicone on the 1/2 moon /head intersections ..
[Re: CJM]
#1026957
08/26/11 06:25 PM
cool thanks. I'll have a burning contract back in Princeton this coming mid-Oct to early Dec. Hopefully this time I will have time to come see you for real!
[Re: allochris]
#1026958
08/31/11 05:54 AM
What an amazing adventure! Good job with all the pictures. What kind of work were you doing? And did it involve that helicopter I saw in the pictures? -- Matt
'89 4runner SR5, 3.0, auto (fun) '93 xtra cab, dlx,3.0, 5spd (work truck)
