Water temperature sensor
Happy Holidays
by plh - 12/29/21 11:04 PM
V5MT1 Confusion
Early Gen I trim levels
Happy Holidays
2 in lift kit worth it?
0 registered members (), 67 guests, and 6 spiders.
Topics138,255
Posts1,081,614
Members15,239
looking for coil springs and issue when driving #1028996 05/24/11 01:27 AM
catman25 Offline OP
hey looking for oem rear coils if any one has them laying around in decent shape .. also while driving there is a nasty vibration with therear tires off there is a little in and out play of the axel i think its been like that . brakes look fine , vibration is under 20 then 45-55 then fine
check out my truck and please sign my guest book *CHECK OUT MY RIDE*
Re: looking for coil springs and issue when driving [Re: catman25] #1028997 05/25/11 12:10 AM
catman25 Offline OP
nasty vibration when under load and original drive shaft joints . would this make sense ? when you give it gas especilaly up hill its worst ,,,, let off gas not as bad ?
Re: looking for coil springs and issue when driving [Re: catman25] #1028998 05/25/11 12:18 PM
Dryver Offline
Check your driveshaft universal joints. I had nasty vibration under load when my 4-wheel drive was engaged because one of the front universals was shot.
Re: looking for coil springs and issue when driving [Re: Dryver] #1028999 05/26/11 08:44 PM
logansportage Offline
Check your tires too. You could have lost a wheel weight.
Re: looking for coil springs and issue when driving [Re: logansportage] #1029000 05/27/11 06:44 AM
Sportege_Panicmech Offline
HI! ooo oooo.. i might be able to aid. Sounds unlikely to be balance as most balance issues begin to be felt at 45mph and up. not at 20. 20 is not enough speed to get a virbration. could be a separated tire. could be a worn U-join as they said. An experienced person in this can distinguish a U-joint vibration since the speed of the axle is 3-4 times that of the rotational speed of the wheels. Therefore your vibration is much faster if it's U-joint/axle related. If it changes intensity on accel/decel/coast, then it's more likely a U-joint as the changing loads on the axle can change the amount of runout (wobble) of the shaft. A loose U-joint will allow a shaft to be not centered like that. 1st, chk Ujoints.. If you find a dry brown powder on the ujoints it is probably from dry and worn out needle bearings in the ujoint. they rust enough and they just crumple and get grinded down to dust and finds it's way out the seals creating play.
Re: looking for coil springs and issue when driving [Re: catman25] #1029001 05/27/11 05:58 PM
I had a vibration just like that.
Was my front shaft front u-joint. It was starting to seize up and was not moving like they should. So, I removed the front shaft and checked out the play and they were in great shape, just seizing up. So I made a little jig out of a 2x6 and 3" wood screws to hold the u-joint in place while I moved the shaft all around. I was spraying lubricant in all the ends to get at the little needle bearings inside. I started off slow so not to break anything and after 30 min or so they were working good as new. Spraying now & then.
No play with any of the little needle bearings at all, just started to seize up.
So doing this may not be the best way or recommended, but it saved me at least $100.00...for now...lol
This happened back in December 2010. Working great still.
Hope this helps.
Good Luck.
Re: looking for coil springs and issue when driving #1029002 07/07/11 04:58 PM
catman25 Offline OP
thanks for all the help it was a bad u joint .. now to find spring as mines are shot .. any one have old ones available from a upgrade or is there a lower cost substitute or the cheapest place to find oem ? thanks again
Re: looking for coil springs and issue when driving [Re: catman25] #1029003 07/08/11 01:39 AM
DRX350 Offline
NAPA Auto parts. Good prices better parts. Not sure the last time I looked at spring prices for a kia, but for a '97 Jeep TJ they're about $120/ea...
PHP: 7.2.34 Page Time: 0.015s Queries: 15 (0.004s) Memory: 2.8546 MB (Peak: 3.1638 MB) Data Comp: Off Server Time: 2022-01-16 18:55:22 UTC
