My first Raider
by ATTILA. 01/13/19 01:29 PM
by tdf46. 01/12/19 12:15 AM
by tdf46. 01/12/19 12:12 AM
Introduction & New Raider
by Mudraider. 01/11/19 04:11 AM
2nd Gen Front Lincoln Locker.
by RockDoc. 01/12/19 10:31 PM
My first Raider
by Flicky8. 01/12/19 03:28 AM
by tdf46. 01/09/19 03:56 AM
0 registered members (), 140 guests, and 6 spiders.
Topics137,963
Posts1,079,873
Members14,874
Sportage Front Susp Spacer Lift Ratio #1031718
07/14/11 08:35 AM
07/14/11 08:35 AM
I
IanxPR  Offline OP
South Africa
Hi
Can anyone help with the 'Lift Ratio' of front suspension spacers. I have a 38mm (1 1/2 inch) spacer in & would like to know what the actual lift is on the wheel (it lifts more due to the mechanical advantage of the control arm) - I want to put 'Yellow' Jeep TJ spings in the back & w0uld like to know how much I must space the front to get the car level
Thanks
Ian
Re: Sportage Front Susp Spacer Lift Ratio [Re: IanxPR] #1031719
07/14/11 05:19 PM
07/14/11 05:19 PM
H
homerdog  Offline
Michigan
Judging by the one I put on mine it's close to 2:1
2011 Kia Forte EX
Re: Sportage Front Susp Spacer Lift Ratio [Re: homerdog] #1031720
07/15/11 07:46 AM
07/15/11 07:46 AM
I
IanxPR  Offline OP
South Africa
Thanks
I have 38mm (3 inch) spacers is front & back - but the back is slightly low (it is the Longbody version). I have a set of Jeep TJ yellow springs (3inch lift) I want to put in the back to level it out & get better rear articulation. This will also help with my departure angle - I am running 30 x 9.50 Hankook MT's
It has a locally (South African) made lift kit in it which consist of fabricated plate spacers (under the struts and rear springs- does anyone have a pic of the spacers you use on the other side of the pond <img src="/forums/images/graemlins/smile.gif" alt="" />
Thanks
Ian
Re: Sportage Front Susp Spacer Lift Ratio [Re: IanxPR] #1031721
07/15/11 12:05 PM
07/15/11 12:05 PM
freddiespyker  Offline
south africa
hi a 2" spacer will give you 4" of lift.the best person to contact on this forum is dennis thompson he helped me a lot to and i am also from south afrika
Re: Sportage Front Susp Spacer Lift Ratio [Re: IanxPR] #1031722
07/15/11 12:23 PM
07/15/11 12:23 PM
H
homerdog  Offline
Michigan
2011 Kia Forte EX
Re: Sportage Front Susp Spacer Lift Ratio [Re: freddiespyker] #1031723
07/18/11 11:21 PM
07/18/11 11:21 PM
logansportage  Offline
Logan, Utah
Dennis actually sold Up Your KIA to Everet. You can still reach both of them here, or you can go directly to the website.
http://upyourkia.com/
The ratio is just under 2:1, but if you calculate 2:1 it will be about right. The max spacer you should use is no more than a 2" spacer because of the amount of drop is all used up at that point and you will also start contacting the drive axle onto the front fork.
Moderated by  Axe Man, DamKia
Page Time: 0.010s Queries: 15 (0.004s) Memory: 1.0126 MB (Peak: 1.1112 MB) Zlib disabled. Server Time: 2019-01-19 08:12:07 UTC
