92
guests, and 4
Posts1,081,774
lift kit
#1032103
07/24/11 11:45 PM
I have a 2000 sportage and lookin to lift it around 4", but cant seem to find any? So lookin for help
Re: lift kit
[Re: darren1]
#1032104
07/25/11 01:12 AM
01 Sportage 4dr,warn hubs,cone air filter,4" lift,1 3/8" body lift,31" treadwright guard dog mts,Incubus offroad wheels
Re: lift kit
[Re: ackerman]
#1032105
07/26/11 12:34 AM
thanks for info!! After doing some reading im now worried that im going to need an adjustable panhard bar? Wondering if this is true and wear i can get my hands on one? Thanks to all!!!
Re: lift kit
[Re: darren1]
#1032106
07/27/11 02:35 AM
Everyone that has one of my kits does not have an adjustable pan hard rod (as far as I know). I did a 4" lift to my 2wd 2 door. and drilled a different hole in the passenger side pan hard rod location. It has worked great so far (about 15k miles) with no side effects. If you are having rubbing issues, I can send you a template of what worked for me, NO GUARANTEE it will work for you, but it is the cost of 2 holes.
Re: lift kit
[Re: darren1]
#1032107
07/27/11 05:04 AM
I have ran my 4" lift for 12 years and over 160,000 miles and have never installed an addjustible panhard bar. I have never had a problem with allignmens, the rear axle is offseet a little but my tires have allways wore even.
Re: lift kit
[Re: DennisThompson]
#1032108
07/27/11 08:08 AM
Running 3" UPYOURKIA. No issues with lift, panhard rod or uneven wear. Tire width, hight and backspacing are the only issue I noticed.
Re: lift kit
#1032109
07/27/11 04:16 PM
Same here, I've got a 4" lift, no adjustable panhard bar, never had it aligned after the lift and have close to 40,000 miles on a set of tires with no unusual wear.
Re: lift kit
[Re: homerdog]
#1032110
08/09/11 12:44 AM
I have the TJ rear coils and I get rubbing on my shocks only on the left side when articulating the axle.
I have the stock wheels, but 31x10.5 tires. The stock wheels pull the tires in where an aftermarket wheel with less back spacing will push it out just a touch to keep it from rubbing.
