by Bigshankhank. 01/16/19 02:43 PM
My first Raider
by ATTILA. 01/13/19 01:29 PM
by tdf46. 01/12/19 12:15 AM
by tdf46. 01/12/19 12:12 AM
Introduction & New Raider
by Mudraider. 01/11/19 04:11 AM
2nd Gen Front Lincoln Locker.
by RockDoc. 01/12/19 10:31 PM
My first Raider
by Flicky8. 01/12/19 03:28 AM
by tdf46. 01/09/19 03:56 AM
1 registered members (Bigshankhank), 108 guests, and 6 spiders.
Topics137,963
Posts1,079,872
Members14,872
Page 1 of 3 1 2 3
Gen 2 Coil Spring Spacers #1036524
10/21/11 05:25 PM
10/21/11 05:25 PM
TheViper  Offline OP
Oregon, USA
So Id like to do some cheap lifting on my montero, and have been searching here, to find out I need the daystar seqoia coil spring spaces.
1)What is the part number for the spacers i need or what year seqoia will fit with the 95 montero?
2)Is ebay the cheapest place to get a pair?
3)Is this something the average guy can do?
Thanks
1995 Montero SR
Re: Gen 2 Coil Spring Spacers [Re: TheViper] #1036525
10/21/11 06:15 PM
10/21/11 06:15 PM
S
Scottie2113  Offline
Phoenix, AZ *****
You could buy my custom springs in the for sale forum for 75 bucks plus shipping and get a whole new spring.
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: Gen 2 Coil Spring Spacers [Re: TheViper] #1036526
10/21/11 06:39 PM
10/21/11 06:39 PM
jdavis  Offline
Seattle, WA
[color:"orange"] Check with Hazy_Daze for part number on the Daystar spacers. He has gotten them for a couple of folks on the board.[/color]
[color:"orange"] Unknown[/color]
[color:"orange"] I'm probably below avg and was able to install them by myself[/color]
Thanks
95 Montero SR
33 x 12.50
Aussie Locker
OME Heavy Duty Coils & Torsion Bars
ARB Front Bumper
76" Trail Gear Rock Sliders
XRC-9.5K Winch
Re: Gen 2 Coil Spring Spacers [Re: jdavis] #1036527
10/21/11 08:08 PM
10/21/11 08:08 PM
heathdogg  Offline
Flagstaff, Az
the Rancho number is RS70081. I ordered them through my work at NAPA. I had a guy at a four wheel shop look them up and these were cheaper then the Daystars. I have a Gen I with the Gen II coils in already. I put these in a few hours. Here's what I did.
1. Put the truck on jackstands and put jacks under the axle.
2. Removed the tires.
3. Unbolted the sway bar from the axle
4. Unbolted the shocks.
5. Unbolted the panhard bar at the frame.
6. Lowered the axle down (Warning: Watch the rubber brake line.)
7. Remove the coil and take off the rubber pad off the top of the coil.
8. Put on the spacer.
9. Cuss like a irishman while you are putting the coils back in.
10. Nurse your sore knuckles and put everything back together.
I had difficulty in reattaching the panhard bar. It was off by about half an inch or so. I used a combination of jacks and prybar to get it to go back. I would recommend a longer brake hose if doing this. I also used longer sway bar links to keep the bar level. I used a 38417 brake hose and a 265-1323 NAPA sway bar kit. Just had to cut the nipples off the get a nice fit.
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: Gen 2 Coil Spring Spacers [Re: heathdogg] #1036528
10/26/11 08:43 PM
10/26/11 08:43 PM
TheViper  Offline OP
Oregon, USA
Thanks very much for the information, those ranchos seem to be the same price as the daystars though.
Thanks everyone for the help, I think coil spacers+torsion bar is the cheap route im gonna take for some lift
1995 Montero SR
Re: Gen 2 Coil Spring Spacers [Re: TheViper] #1036529
10/26/11 09:10 PM
10/26/11 09:10 PM
RECON45  Offline
Statesville, NC
Could you not use the coil spring compressor tool to save some aggrivation?
Re: Gen 2 Coil Spring Spacers [Re: RECON45] #1036530
10/26/11 09:13 PM
10/26/11 09:13 PM
off-roader  Offline
Bay Area, CA *****
The compressor tool isn't needed. Simple/easy enough to disconnect the rear shocks as you raise the rear and lower the axles. The springs will drop out and there's enought room to insert the springs with spacers.
Off Roader
96SR (3.15:1 xcase, 35's)
96SR Build Up Thread
Old web page
Old web page
Re: Gen 2 Coil Spring Spacers [Re: off-roader] #1036531
10/26/11 11:44 PM
10/26/11 11:44 PM
heathdogg  Offline
Flagstaff, Az
Depends on how high you can get the truck up. The stands I borrowed were tall just not enough for my purpose. So I had to massage them back in a little. And the trailing arms were still bolted too. I'm sure it would have been easier if I had loosened the nuts a little cause I couldn't get the truck that high. All I needed was an inch more. I'm sure the jackstands sunk a little in the damn dirt driveway. I might also add I am using longer shocks too. 80-96 Ford Bronco's. Cause I haul wood at unreasonable speeds over bumpy roads, <img src="/forums/images/graemlins/smile.gif" alt="" /> I am using the NAPA Gas Grande's. We'll see how long these last. I blow out the weannie stock style one's in under a year and the RV's about year and a half. Haven't blown the fronts out yet though.
Re: Gen 2 Coil Spring Spacers [Re: heathdogg] #1036532
10/27/11 12:31 AM
10/27/11 12:31 AM
off-roader  Offline
Bay Area, CA *****
Jack stands?
Chocked the front tires securely.
Disconnected the pan hard rod.
Used a pair of hiLifts on the rear bumper to raise the rig, then used a floor jack on the rear pumpkin to lower it down (after disconnecting the shocks) then raise it back up after installing the springs.
We did have jack stands in place underneath just in case.
Was pretty straight forward and quick.
Re: Gen 2 Coil Spring Spacers [Re: off-roader] #1036533
10/27/11 05:10 PM
10/27/11 05:10 PM
heathdogg  Offline
Flagstaff, Az
I've only got the one hi-lift and it don't work so well on my uneven driveway. My other truck is getting Gen II coils in it soon. I'm going to cheat and use my friends garage this time. It's a little nippy here now and it's got heat, tools, lights and t.v. No fridge though <img src="/forums/images/graemlins/frown.gif" alt="" />.
Page 1 of 3 1 2 3
Page Time: 0.014s Queries: 16 (0.005s) Memory: 1.0680 MB (Peak: 1.2089 MB) Zlib disabled. Server Time: 2019-01-16 16:43:12 UTC
