97
Posts1,080,940
Re: my 2WD build
[Re: Cochip]
#1036643
10/28/11 04:19 AM
that is just the "mock up" engine .. I have already built the 7mGTE ![[Linked Image]](http://www.members.shaw.ca/slacker502/IM001571.JPG) should be ~ 400 RWHP .
Re: my 2WD build
[Re: CJM]
#1036644
10/28/11 06:00 AM
Very nice. I love my '94 with a 7MGE, this truck will scream with a 7mGTE!!
BTW I've heard that the "third head gasket",(swear the manual I read called it that),tends to leak over time causing oil to pool in each of the spark plug locations. Did you do anything to address this? I ended up unscrewing the three plugs and placing a oil plug gasket there along with the factory gasket and then re-tightening them.
Re: my 2WD build
[Re: Cochip]
#1036645
10/29/11 01:28 AM
Yep .. I used a Cometic Metal head gasket and ARP head studs , as well as the new tube gaskets .. I'm sure I used silicone on the tube seal tops as well , but honestly , I built the engine 5 years ago .. prepping the inner rockers for the new body mounts .. I of course found rust <img src="/forums/images/graemlins/frown.gif" alt="" /> .. so now I have to fix that first .. I was really surprised , this cab was in awesome shape no rust at all , or so I thought .. just goes to show you , even if you think you have no rust .. you probabally do !! undercoating wire wheeled off , and looking great ![[Linked Image]](http://i76.photobucket.com/albums/j2/bj_bumperboy/hot%20rod/SSPX1312.jpg) and cut out rust !! ![[Linked Image]](http://i76.photobucket.com/albums/j2/bj_bumperboy/hot%20rod/SSPX1311.jpg) .
Re: my 2WD build
[Re: CJM]
#1036646
10/30/11 01:54 AM
1 side done .. and ready ![[Linked Image]](http://i76.photobucket.com/albums/j2/bj_bumperboy/hot%20rod/SSPX1313.jpg) .
Re: my 2WD build
[Re: CJM]
#1036647
11/01/11 01:49 AM
also got the drivers side cleand and prepped this weekend ![[Linked Image]](http://i76.photobucket.com/albums/j2/bj_bumperboy/hot%20rod/SSPX1315.jpg) and <img src="/forums/images/graemlins/frown.gif" alt="" /> .. drivers side has rust as well ![[Linked Image]](http://i76.photobucket.com/albums/j2/bj_bumperboy/hot%20rod/SSPX1316.jpg) I think to be safe , i'm going to cut it all out .. front and back rocker area , and strengthin both sides before I build the body mounts and just for some giggles .. heres the pile of removed edging and ground steel .. ![[Linked Image]](http://i76.photobucket.com/albums/j2/bj_bumperboy/hot%20rod/SSPX1314.jpg) .
Re: my 2WD build
[Re: CJM]
#1036648
11/12/11 03:59 AM
so over the last week , I have been building my repair panels and today I was able to get them burnt in , rears as well ![[Linked Image]](http://i76.photobucket.com/albums/j2/bj_bumperboy/hot%20rod/SSPX1315-1.jpg) ![[Linked Image]](http://i76.photobucket.com/albums/j2/bj_bumperboy/hot%20rod/SSPX1324.jpg) now with the rockers repaired , I was able to get the cab height finalized @ 9" from the rockers to the Ground . + I also started on the cab mounts Because there are only going to be 4 mounts instead of 6 , I wanted to make sure there were going to be strong . cut out some 3/16" plate and surrounded it with some tube ![[Linked Image]](http://i76.photobucket.com/albums/j2/bj_bumperboy/hot%20rod/SSPX1326.jpg) Tacked into place I will add some more supports later , when I turn the frame over . ![[Linked Image]](http://i76.photobucket.com/albums/j2/bj_bumperboy/hot%20rod/SSPX1327.jpg) 1 more front frame mount tomorrow , then I can get on the front cab mount .
Re: my 2WD build
[Re: CJM]
#1036649
11/13/11 03:38 AM
and cab side mount Bent up some 1/2" solid stock with the 3/16" plate . as well as a "fish plate" for the cab side , 1/2" stock actually goes threw the fish plate for a stronger "plug" weld , and a toyota stock body mount bushing , I now have the front mounted ![[Linked Image]](http://i76.photobucket.com/albums/j2/bj_bumperboy/hot%20rod/SSPX1328.jpg) ![[Linked Image]](http://i76.photobucket.com/albums/j2/bj_bumperboy/hot%20rod/SSPX1331.jpg) and now the front of the cab is mounted still have some supports and final welding to do when I can turn over the frame , but for now it's good to go also .. the cab now has it final "stance" ![[Linked Image]](http://i76.photobucket.com/albums/j2/bj_bumperboy/hot%20rod/SSPX1329.jpg) ![[Linked Image]](http://i76.photobucket.com/albums/j2/bj_bumperboy/hot%20rod/SSPX1330.jpg) acetone can for referance .... .
Re: my 2WD build
[Re: CJM]
#1036650
11/13/11 11:23 PM
<img src="/forums/images/graemlins/cheers.gif" alt="" /> def going to be something i would like a ride in!
"I am a shrubber, my name is Rodger the Shrubber. I arrange, design, and sell shrubberies"
Re: my 2WD build
[Re: Rodgertheshrubber]
#1036651
11/15/11 03:07 AM
as long as it's a "fair weather" day, your welcome to come along
Re: my 2WD build
[Re: CJM]
#1036652
11/20/11 03:10 AM
got to work today making the rear cab mounts ![[Linked Image]](http://i76.photobucket.com/albums/j2/bj_bumperboy/hot%20rod/SSPX1346.jpg) as with the fronts .. plug welded ![[Linked Image]](http://i76.photobucket.com/albums/j2/bj_bumperboy/hot%20rod/SSPX1347.jpg) and yeah!!! , cab is no mounted to the frame ![[Linked Image]](http://i76.photobucket.com/albums/j2/bj_bumperboy/hot%20rod/SSPX1348.jpg) .
