93
Posts1,081,774
Problem with heater blower motor
#1038081
11/17/11 07:11 AM
We recently had a bunch of snow . It melted and I noticed water pooling on the front passenger floor. I found the source of the leak and repaired it. Few days later I smell something burning . The heater blower motor died . I take it out , it clearly has water damage. I replaced with a new blower motor from kia . My resistor looked bad (stained ), So I raplaced it with one from a 2000 model from the junk yard. I install everything and it works but the blower motor stays on high and does not shut off till you stop the engine . You can adjust hot/cold , direct vents . but cannot lower blower motor speed or turn off. <img src="/forums/images/graemlins/angry.gif" alt="" />
Re: Problem with heater blower motor
[Re: 88thunderbird]
#1038082
11/18/11 01:13 AM
I would guess your used resistor is bad.
01 Sportage 4dr,warn hubs,cone air filter,4" lift,1 3/8" body lift,31" treadwright guard dog mts,Incubus offroad wheels
[Re: ackerman]
#1038083
11/19/11 05:56 AM
I wonder if your fan switch was damaged coinsidently. Inside the fan switch there's a metal tab or something that can break (if I remember correctly) and can be glued back together. It's a metal tab held on by plastic rivets i think. Silly Kia design. I'm not a Kia fan.. I'm a mazda fan. lol. anyway. The problem cant be the resistor. If the blower motor is blowing full speed in every switch position 0,1,2,3,4; then the resistor isn't the problem. the resistor receives its power from the switch so.... if your switch is set to off.. then which is the resistor still receiving and passing along power to the fan? no, the switch is still sending power when it shouldn't.. pull apart your fan switch and fix it. pull the knob off (pressed on) I think they can be fixed without pulling the center console. i think.. lol it's been a while.
[Re: Sportege_Panicmech]
#1038084
11/19/11 07:12 AM
I wonder if your fan switch was damaged coinsidently. Inside the fan switch there's a metal tab or something that can break (if I remember correctly) and can be glued back together. It's a metal tab held on by plastic rivets i think. Silly Kia design. I'm not a Kia fan.. I'm a mazda fan. lol. anyway. The problem cant be the resistor. If the blower motor is blowing full speed in every switch position 0,1,2,3,4; then the resistor isn't the problem. the resistor receives its power from the switch so.... if your switch is set to off.. then which is the resistor still receiving and passing along power to the fan? no, the switch is still sending power when it shouldn't.. pull apart your fan switch and fix it. pull the knob off (pressed on) I think they can be fixed without pulling the center console. i think.. lol it's been a while. Thanks for the info . Something i will check into . I'm not doing any work outside till it warms up . it's -19 c here right now lol!
[Re: 88thunderbird]
#1038085
11/19/11 09:49 PM
ouch that's cold.. North Idaho's in the positive teens tonight i believe.. burr.. I was raised in Florida, lol. but i love it up here. and love this snow!!
