0 registered members (), 76 guests, and 2 spiders.
Rear Axle Alignment #1038248 11/20/11 10:24 PM
R
rccrwlr Offline OP
My rear axle seems to have shifted back about 2". The drive line does not look extended, the spring packs don't show a shift. About 2 years ago I had a Transmission put in and my dad has had the jeep since then. We have a 4" super lift and the leaf packs seem to be facing the correct way but i don't have any measurements to confirm the correct install direction. Any ideas as to how to correct the sift?
Photos
https://picasaweb.google.com/10086419201...&feat=email
Re: Rear Axle Alignment [Re: rccrwlr] #1038249 11/21/11 03:47 PM
MartySoCal Offline
Good chance that the center bolt/s in the spring pack/s is broken. You would need to take the u-bolts loose enough to see if the center bolt/s has sheared off or not. New bolts are available though your local parts store in the Dorman Products brand line.
The main cause of this happening is that the axle u-bolts were not properly torqued, and re-torqued after the lift kit was installed. If you put a torque wrench on the u-bolts, they should be tightened to about 75 ft lbs if they are 1/2", 55 ft/lbs if they are 7/16". An air impact gun will not fully torque them, use a torque wrench. They will need re-torquing after the first test drive, then after about a week, then after each off-road trip, until you are sure they are holding their torque. New u-bolts stretch out. I recheck them at every oil change on my CJ.
I bet if you go and try to torque the u-bolts (Front and rear) you will find them loose.
Moderated by  4x4Wire
PHP: 7.4.30 Page Time: 0.023s Queries: 15 (0.008s) Memory: 2.8503 MB (Peak: 3.1928 MB) Data Comp: Off Server Time: 2022-07-03 11:35:08 UTC
