Posts1,081,743
sportage engine question and towing question #1041180 01/31/12 03:01 PM
bingocouple Offline OP
is the 2.0 and 2.7 engines swappable? I would like a bit more power.
Also, how much weight can I tow with my sporty? Like a 20ft travel trailer.
Re: sportage engine question and towing question [Re: bingocouple] #1041181 02/01/12 02:08 PM
2002_Sporty Offline
Engine Type DOHC 16-valve 2.0 Liter I4 w/SMFI
Engine Size 122 cid/1998 cc
Horsepower 130 @ 5500 RPM
Torque (lb-ft) 127 @ 4000 RPM
Wheelbase/Width/Length 104.3"/68.1"/170.3"
Transmission Five-speed manual
Curb Weight 3379 pounds
Fuel Capacity 15.8 gallons
Tires (F/R) P205/75R15
Brakes (F/R) Disc /drum
Drive Train Front-engine/four-wheel-drive
Vehicle Type Five-passenger/five-door
MPG city/highway/average 19/22/20
Zero to Sixty 13.5 seconds
Maximum payload capacity 860 pounds
Maximum towing capacity 2000 pounds
I would use an electronic brake if possible over 1500 pounds. I've tow more than this regularly on flat ground during the summer. But 2000 Lbs is quite risky on mountains.
I do not condone nor take responsibility of any activity that will endanger you or others.
Found these pics from Kia-Forums and some other Aussie site.
2002 4dr Kia Sportage 4X4
Re: sportage engine question and towing question [Re: 2002_Sporty] #1041182 02/02/12 03:55 AM
Sportege_Panicmech Offline
Nice! The pics with the Washington plates have familiar scenery.. I'm from Easter Washington/NorthIdaho area. That area looks like central Wash.. Who owns the Wash plate kia? Might be close enough to me for a meet up. Impressive pics.. I knew they were capable of towing a good amount, however after seeing this I'd suggest anyone actually towing that much aught to get the lift to aid the weight load. Especially if your running oversized tires.
Re: sportage engine question and towing question [Re: Sportege_Panicmech] #1041183 02/02/12 06:45 AM
DRX350 Offline
Yeah, I'd really recommend that you NOT tow anything over 2500 lbs, ever...
I'm speaking from experience, I nearly lost my rig when I was making a dump run with 3200lbs. I had the trailer loaded properly and I was going about 50 when I started the death sway, Luckily, I was headed for an uphill that I could safely slow down on.
If you find your self in a sticky situation while towing (such as a sway), NEVER hit the brakes, you'll spin out...
I do however tow my 1100lb tent trailer several thousand miles a year, and average 18.5mpg doing so! I run a small cooler on the trans, an electric radiator fan, and a 3" lift w/ 235/75s.
Re: sportage engine question and towing question [Re: DRX350] #1041184 02/05/12 01:01 AM
jays2001 Offline
im not sure about the 5 speed weight but my auto weighs in at 4020lbs with out all my trail geer. i ran it across our scales at work. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: sportage engine question and towing question [Re: jays2001] #1041185 02/05/12 03:30 AM
DRX350 Offline
Well after several runs to the metal scrap yard, my 2 door weighs 2840-ish empty with a 1/8 tank of gas. With my camper and all the crap associated with the trip, my set-up weighed 4120, and that was with a full tank of gas. Mines an auto 2wd btw...
Re: sportage engine question and towing question [Re: DRX350] #1041186 02/17/12 02:43 PM
2002_Sporty Offline
PHP: 7.4.30 Page Time: 0.027s Queries: 15 (0.010s) Memory: 2.8803 MB (Peak: 3.1933 MB) Data Comp: Off Server Time: 2022-06-27 11:05:49 UTC
