75
guests, and 4
Topics138,179
Posts1,081,008
Re: 1988 Montero Turbo Diesel build
[Re: TOASTY]
#1043377
05/03/12 07:50 PM
Took off the solenoid, it has corrosion. But the thing doesn't really come apart, it's stamped together any suggestions? i could grind the stamped dimples. I could also run it through a anti corrosion solvent and move it and shake it a bunch.
1999 Montero Blizzard package
1991 Montero RS
[Re: TOASTY]
#1043378
05/05/12 05:53 PM
Pry out the stamped dimples. Then "stamp" them back after you've heehaw repaired it. Thats how I do it.
87 Raider 4D56td v5MT1 31's..Basically Stock
[Re: LandRaider]
#1043379
05/20/12 08:24 PM
Starter is FAQ'd, either way here's some updates. the pics will resize eventually. Cleaned and installed new rubber on the fuel tank, then installed that sucka Stripping paint sucks, i stripped each section down to all shiny bare steel and then primed one section at a time. Here's the driver rear quarter panel almost stripped down and the driver door stripped and primed. primed with the roof painted Gloss white, and yes i know i didn't i didn't prep the roof as well as the sides but who's gonna look at the roof? ![[Linked Image]](http://i1093.photobucket.com/albums/i428/sneakyninjaaction/Montero%20build%20pics/DSCF0168.jpg) transfer cases with shifters installed sight glass and breather fittings installed ![[Linked Image]](http://i1093.photobucket.com/albums/i428/sneakyninjaaction/Montero%20build%20pics/DSCF0166.jpg)
1991 Montero RS
[Re: TOASTY]
#1043380
05/21/12 02:03 AM
Looks awesome, my hat is off to you!METALMOVER
1987 Raider,2.6,mt,78"Meyer snow plow,100lb. Doberman alarm,weber carb, lockouts from here- 1989 V-6,SWB, A.T. 4x4, 31'S
[Re: METALMOVER]
#1043381
05/21/12 04:09 AM
I might have also changed my mind on the main color as well, i found a dark green i really like.
1991 Montero RS
[Re: TOASTY]
#1043382
05/21/12 01:16 PM
You might want to leave the top white anyway, if your in a state where theres lots of sun and hot temps. (wink wink)Just a thought.
[Re: TOASTY]
#1043383
05/22/12 02:06 AM
Gloss white, and yes i know i didn't i didn't prep the roof as well as the sides but who's gonna look at the roof? That would depend on what kind of 4-wheeling you're planning to do with it.
95 Montero SR 3.5 OME shocks & springs, cranked torsion bars, 2" body lift, 3" gas tank lift, 4.90 gears, Aussie front locker, factory rear locker, Aisin manual hubs, Roger Brown Rock Sliderz, 315/75r16 (35") tires, 2 1/4" exhaust with Magnaflow muffler
[Re: ryany]
#1043384
05/23/12 07:06 AM
Here is a perfect source for turbo diesel lovers. Late model 2008 Mitsubishi L200 crew cab pickup STATESIDE in Tucson. http://gsaauctions.gov/gsaauctions/aucdsclnk?sl=91QSCI12174531 According to VIN that thing supposed to have 2.8TD 4M40 engine, easy select. That's obviously a drug repo or something like that. I conversed with custodian The truck doesnt run and hasnt in quite some time. The dash wiring has been cut, holes in dash cut. Interior is disassembled, exhaust system missing. Sounds they were very thorough checking every hollow. Auctions ends TOMORROW!!! That might be only chance in loooong time to have something like that in us. Some enterprising sole might try to register that in non-emmission checking state. You'd be on your own. You should be able to source parts from Mexico where it's sold. http://www.mitsubishimotors.com.mx/index.php?s=modelos&m=detalle&a=9 <img src="/forums/images/graemlins/cheers.gif" alt="" />
92 SR, 285/75R16 Yoko MT ARB locker GAST compressor AirLift 1000 MM10500 Snorkel custom rear bumper 02 Montero LS died protecting the master 08 PowerWagon (stock!)
[Re: Alex Kogan]
#1043385
05/23/12 04:51 PM
Damnit. That would have been a cool thing to buy.
1991 Montero RS
STARTED!
[Re: METALMOVER]
#1043386
06/02/12 10:03 PM
Got the engine started today! Runs pretty good too, needs some fine tuning but this was the last big thing. I did the hot torque on the head and re sealed the valve cover. I can now start gathering the accessories and installing them so i can get this pig in the Montero. Here's the video First running of the engine!
1991 Montero RS
