How are vaccinations going in Europe?
by gmong - 02/26/21 04:07 AM
Replacement MAF unit .. Gen1
Gen1 cigarette lighter port.
GEN I Auto hubs
by polar - 02/16/21 03:03 AM
GEN I Auto hubs
0 registered members (), 114 guests, and 6 spiders.
Topics138,177
Posts1,081,002
Page 2 of 3 1 2 3
Re: Tranny Clunk backing up! [Re: allochris] #1044267 04/02/12 01:45 AM
kewlynx Offline
Zuk hasn't been around in awhile. Might see if he's got some inspection specs for your locker, or knows where you might find 'em.
www.gearinstalls.com Give him a holler.
I am also going to STRONGLY suggest you get that driveline balanced after replacing the U-joints. I've had my wheel/spline depart a truck a few years back; found out my main D/L had gotten bent somewhere along the line, as the ujoints were fine.
Keep in mind that you had a lot of twisting torque on that thing, so get it looked at to make sure it's still true, or you'll be back under there in about 6 months.
**ubi apis- ibi salus**
Re: Tranny Clunk backing up! [Re: kewlynx] #1044268 04/02/12 02:08 AM
G
Greg_Canada Offline
I would replace the bearings.
As for the LSD, pull it apart and rebuild it. Would not want to find more particles inside it!!
89 4Runner
Re: Tranny Clunk backing up! [Re: Greg_Canada] #1044269 04/02/12 03:37 AM
kewlynx Offline
Yep that at least. Stuff didn't get that way entirely on its own. Chris, was that a pull-n-play LSD perchance?
Re: Tranny Clunk backing up! [Re: kewlynx] #1044270 04/02/12 05:41 AM
A
allochris Offline OP
Ok, yesterday it took me like 1 hour to wipe "clean" the inner housing. The tiny metal flakes were just everywhere!
The old supra LSD was directly pulled from a supra & implanted with v6 auto 4.88 ring & pinion & 1 side carrier bearing. As for performance wise over the last 6 yrs, it didn't grab as much as I wanted to on slippery gound. I should have added more shims/washers inside the LSD.
My friend (heavy duty mechanic, not car mechanic though) helped me 6 yrs ago to setup the pinion/carrier bearings preload. It was our first time & following fsm instruction, at least it did lasted about 105000km though.
Too bad i'm in a rush to get the truck running by next weekend. I won't deal with my old 3rd for now. I'm just going to find a replacement 3rd from junkyards locally on Vancouver Island and Vancouver. If I don't have any luck, I might have to bite the bullet & buy the drop-in unit from Marlin at $650!!! We'll see, lots of phone calls tomorrow.
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
Re: Tranny Clunk backing up! [Re: kewlynx] #1044271 04/02/12 05:46 AM
A
Will do!
Are you refering to the driveshaft getting unbalanced on its own from wear & tear? or from my diff gear slipping?
Re: Tranny Clunk backing up! [Re: allochris] #1044272 04/02/12 06:12 AM
A
Can anyone please confirm the year range of the rear 3rd that comes with 4.88?
-92'-95' 4runner v6 auto with 31" tires?
-There's a VIN/gear code for that gear ratio identification right?
-Pinion nut has a pink mark?
Re: Tranny Clunk backing up! [Re: allochris] #1044273 04/02/12 06:28 AM
A
Found my info from: Erik's Toyota Differential Info
The FACTORY 4.88 V6 diff is unique!
- Axle code G144, white pinion paint code,
- generally came in 92-95 trucks/4runners with V6, auto tranny, 31" tires, and tow package.
- Housing offsets pinion towards ring gear, allowing ring gear to be thinner
- OEM Toyota gears are the ONLY gears that fit this diff due to the thinner ring gear. All other gear sets have thicker ring gears and do not fit.
- The carrier (case) is the same as the V6 diffs, so normal V6 lockers, LSD's, etc. will work in this diff
Re: Tranny Clunk backing up! [Re: allochris] #1044274 04/02/12 06:35 AM
kewlynx Offline
In my case, I might've bent the D/L on an obstacle without realizing it. The D/L doesn't 'wear/tear' quite as your u-joints do. Ever see one grenade before? It's pretty gnarly, esp if the front of the D/L hits the ground while you're in motion <img src="/forums/images/graemlins/zombie.gif" alt="" /> Glad that didn't happen to your girlfriend.
Either way, they can't/won't balance your D/L without new ujoints installed; takes the slop out of it so they can set it up properly for you. Science in action.
Re: Tranny Clunk backing up! [Re: kewlynx] #1044275 04/02/12 04:10 PM
G
Greg_Canada Offline
89 4Runner
Re: Tranny Clunk backing up! [Re: Greg_Canada] #1044276 04/03/12 04:25 AM
A
ya, i sourced a used rear a 4.88 diff from Nanaimo on the island today. $20 shipping to the door where my truck is sitting! It got pulled out today, i'll find out tomorrow about its condition. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Page 2 of 3 1 2 3
PHP: 7.2.34 Page Time: 0.031s Queries: 16 (0.008s) Memory: 2.8947 MB (Peak: 3.1634 MB) Data Comp: Off Server Time: 2021-02-26 16:29:35 UTC
