82
Posts1,080,940
Limited slip axle code?
#1046260
05/08/12 06:58 PM
What is the code for the limited slip rear diff? I want to start scouring the salvage yards for a limited slip.
Re: Limited slip axle code?
[Re: promodmerc]
#1046261
05/10/12 10:51 PM
After some deeper searching it appears KIA does not differentiate between an open diff or limited slip diff <img src="/forums/images/graemlins/angry.gif" alt="" />
I'm so use to Ford doing this I figured every car mfg did.
[Re: promodmerc]
#1046262
05/18/12 03:43 PM
It's in the serial number somewhere, I have no idea where though. I ran mine once and limited slip showed up as one of the options.
[Re: homerdog]
#1046263
05/20/12 11:38 PM
Masterjeep.com sells them new for about 530$
[Re: Xander]
#1046264
05/25/12 02:32 PM
Most salvage yards have the cars off the ground some with tires removed, with everything in neutral turn one of the brake drums (tires if still on), if the other side turns the same direction it has limited slip, if it turns the opposite direction it's open or a wore out minted slip.
[Re: promodmerc]
#1046265
05/29/12 12:35 AM
Not sure if it would apply to your guy's Sportages, but the Sorentos have a label above the pumpkin on the rear that indicated if it is "LSD" or not, also gives the ratio (either 3.333 or 4.666 on our Kia 10 bolts) http://www.bit4net.com/images/sorento/rear-axle/P1020677.jpg
2005 Kia Sorento LX - 3.5L with 5 speed manual 2" Daystar spring spacer lift - 265/75R16 BFG's fitted Custom front bumper with hitch mount, sliders, engine skid.
