111
Topics138,201
Posts1,081,246
engine struggling? - heres a simple solution
#1046845
05/20/12 10:19 AM
hey guys.
A friend of mine had a problem with is sporty - on serious acceleration it was lacking in power. everything was checked - sensors - catalitic converter - all were fine. finally he noticed that as the years pass - the lining on the inner part of the hood tends to sag and block the air intake. 10 minutes later and one pair of scissors - the sporty was back on its feet!
2001 sporty. 4 inch lift+ body lift-front lovlells coils+extended forks. reat tj. monroe shocks. full skid plate, auxilary fan. external oil cooler. maxxis 8060 235/75 R15 tires on american racing wheels. trackfinder rear diff lock. http://www.cardomain.com/ride/3948684/2001-kia-sportage
Re: engine struggling? - heres a simple solution
[Re: hadtomer]
#1046846
05/20/12 05:04 PM
This was written about a few years ago on the forum but it is a good reminder of something else to check!! Thanks! Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: Everet]
#1046847
05/20/12 11:22 PM
I'll have to check mine. I know it's sagging enough that it is rubbing on the plastic engine cover.
[Re: promodmerc]
#1046848
05/21/12 03:16 PM
That was one of the first things to go when I got mine. It looks a lot cleaner that way...
[Re: DRX350]
#1046849
05/21/12 04:08 PM
That was one of the first things to go when I got mine. It looks a lot cleaner that way... I've been seriously thinking of removing mine.
[Re: promodmerc]
#1046850
05/22/12 08:31 AM
It gets sub zero in the winter where I live. So I have to retain mine to aid with keeping the lil 4-banger up to temp. Good write up though.
