guests, and 3
Topics138,274
Posts1,081,733
Shackle Bushings?
#1046937
05/21/12 11:47 PM
Trying to find new shackle bushings. I would prefer the polyurethane since they last way longer, but I cant even find the rubber ones. I did find them from an online toyota parts warehouse for 100.
Anyone got a source.
Re: Shackle Bushings?
[Re: CJMT100]
#1046938
05/22/12 04:39 PM
Check with 4Crawler, he's a board moderator. He builds custom shackles, but he may be able to hook you up with a good bushing source. 4Crawler's Product Page From www.toyodiy.com I get the following for the factory bushing part #'s. The prices are pretty appealing <img src="/forums/images/graemlins/kewl.gif" alt="" /> : 48210A BUSH(FOR REAR SPRING SHACKLE UPPER) 90385-18017 RCK10, VCK1*, 2* Qty=4 $4.11 48210G BUSH(FOR REAR SPRING SHACKLE LOWER) 90385-18016 RCK10, VCK11, 21 Qty=4 $3.56 From what I understand, the poly bushings tend to be squeaky.
1997 T 100 4X4 ExtraCab 5 speed, White Worthless factory bedliner 265/75/16 Firestone Destination A/Ts Aisin Manual Hubs 90k miles
[Re: Perpetrator]
#1046939
05/22/12 07:36 PM
Gees what the heck did I find then-I guess the price for the shackle itself.
Ill contact 4 crawler and see what he says, I dont want the rubber bushings b/c they tend to wear out too easy and I dont want to do this job again anytime soon.
[Re: CJMT100]
#1046940
05/22/12 09:47 PM
Energy suspension bushings are what i run.
[Re: Greg_Canada]
#1046941
05/22/12 10:59 PM
Energy suspension bushings are what i run. Got a link or part number?
[Re: CJMT100]
#1046942
05/24/12 01:46 AM
Ive contacted 4crawler and am awaiting a response to have some shackles built with poly bushings. Im sure if I were to try and remove the ones on there now I would have issues due to rust and corrosion.
I also found daystar apparently lists toyota pick up 89-05 shackle bushings as fitting a t100. No idea if its right but I cant chance it once I have everything apart.
Also found a few new non oem shackles for about 70/pc online. Pretty reasonable but no idea the real quality.
