Smoking winch
by Mudraider - 04/11/21 03:16 AM
Power steering pump leak.
replace master cylinder
Ignition Coil
Smoking winch
Gen 1 starting issue
by Oso - 04/01/21 05:28 AM
0 registered members (), 82 guests, and 5 spiders.
Topics138,201
Posts1,081,241
a strange fan problem-need some advice #1047598 06/02/12 06:26 AM
H
hadtomer Offline OP
Hey guys. on the last few weeks the sporty has been making an unpleasent noise on start up. after 2 minutes the noise is gone. after alot of searching the source of the noise was found- the fan is touching the bottom of the fan cover (i think you guys call it the radiator shroud) - its not touching the rad itself-but the black plastic cover around the fan. also- when the problem settles down and all is well- when i go offroad and go into situations when the rear suspensionflexes- the noise comes back. i can understand a busted motor mount (they are fine-checked them)-cause i guess the problem is that the engine has indeed moved about an inch for some reason-but why does this happen only on cold start and when the rear suspension is flexing? ideas? i dont want to break the fan......eventually.
Re: a strange fan problem-need some advice [Re: hadtomer] #1047599 06/03/12 04:27 AM
Is the clutch loose/coming apart?
Check your radiator mounts too. I run electrics so can't go out an look.
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: a strange fan problem-need some advice [Re: Everet] #1047600 06/03/12 05:35 AM
H
hadtomer Offline OP
if you mean my fan clutch - its fine. if you mean my cars clutch - its an auto.
PHP: 7.2.34 Page Time: 0.024s Queries: 15 (0.007s) Memory: 2.8304 MB (Peak: 3.1636 MB) Data Comp: Off Server Time: 2021-04-11 10:54:41 UTC
