72
Topics138,179
Posts1,081,008
a strange fan problem-need some advice
#1047598
06/02/12 06:26 AM
Hey guys. on the last few weeks the sporty has been making an unpleasent noise on start up. after 2 minutes the noise is gone. after alot of searching the source of the noise was found- the fan is touching the bottom of the fan cover (i think you guys call it the radiator shroud) - its not touching the rad itself-but the black plastic cover around the fan. also- when the problem settles down and all is well- when i go offroad and go into situations when the rear suspensionflexes- the noise comes back. i can understand a busted motor mount (they are fine-checked them)-cause i guess the problem is that the engine has indeed moved about an inch for some reason-but why does this happen only on cold start and when the rear suspension is flexing? ideas? i dont want to break the fan......eventually.
2001 sporty. 4 inch lift+ body lift-front lovlells coils+extended forks. reat tj. monroe shocks. full skid plate, auxilary fan. external oil cooler. maxxis 8060 235/75 R15 tires on american racing wheels. trackfinder rear diff lock. http://www.cardomain.com/ride/3948684/2001-kia-sportage
Re: a strange fan problem-need some advice
[Re: hadtomer]
#1047599
06/03/12 04:27 AM
Is the clutch loose/coming apart? Check your radiator mounts too. I run electrics so can't go out an look. Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Everet]
#1047600
06/03/12 05:35 AM
if you mean my fan clutch - its fine. if you mean my cars clutch - its an auto.
