1 registered members (MarkG),
123
guests, and 4
Topics138,205
Posts1,081,260
New in here!
#1049773
08/07/12 05:11 PM
Hello I'm new here but old with the sportage. I have a 1996 a/t 2.0 Rear tf locker Front welded 5" lift in back 2" front eibach springs with 2" spacer Front diff lowerd 2" 235x75 r15 maxxis 8060 External gear cooler
My question is like this.. I'm thinking of a engine swap I received a vr6 from a friend and I'm thinking of swapping it with the sportage old engine! Can any one tell me if there Is a way of connecting the sportage gear box to the vr6 casing??
Re: New in here!
[Re: Leop988]
#1049774
08/07/12 06:35 PM
How much duct tape do you have?
jk, no, there's no way to connect those. Unless you make an intermediate shaft or can machine an adapter plate...
Re: New in here!
[Re: Leop988]
#1049775
08/08/12 11:55 AM
TROLLS- they live under bridges, dont they?
2001 sporty. 4 inch lift+ body lift-front lovlells coils+extended forks. reat tj. monroe shocks. full skid plate, auxilary fan. external oil cooler. maxxis 8060 235/75 R15 tires on american racing wheels. trackfinder rear diff lock. http://www.cardomain.com/ride/3948684/2001-kia-sportage
Re: New in here!
[Re: Leop988]
#1049776
08/09/12 01:31 AM
My question is like this.. I'm thinking of a engine swap I received a vr6 from a friend and I'm thinking of swapping it with the sportage old engine! Can any one tell me if there Is a way of connecting the sportage gear box to the vr6 casing?? Well, 1 guy cut the mounting piece of the transmission off the sportage and cut and welded a piece off the mating part of a transmission that mated to the "new" motor on to the trans. This worked because he measured and did it correctly. Think it was a diesel Sportage to 2.8 GM 6 cyl. Or, some type of CUSTOM, 1 off adapter plate should work. ON ANOTHER NOTE... PLEASE SEND PICS OF YOUR DROPPED FRONT AXLE. I AM LOOKING AT DOING THIS AND WOULD LIKE TO SEE HOW YOURS LOOKS. ANY HELP WOULD BE APPRECIATED. Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: New in here!
[Re: Everet]
#1049777
08/09/12 03:38 AM
My question is like this.. I'm thinking of a engine swap I received a vr6 from a friend and I'm thinking of swapping it with the sportage old engine! Can any one tell me if there Is a way of connecting the sportage gear box to the vr6 casing?? Well, 1 guy cut the mounting piece of the transmission off the sportage and cut and welded a piece off the mating part of a transmission that mated to the "new" motor on to the trans. This worked because he measured and did it correctly. Think it was a diesel Sportage to 2.8 GM 6 cyl. Or, some type of CUSTOM, 1 off adapter plate should work. ON ANOTHER NOTE... PLEASE SEND PICS OF YOUR DROPPED FRONT AXLE. I AM LOOKING AT DOING THIS AND WOULD LIKE TO SEE HOW YOURS LOOKS. ANY HELP WOULD BE APPRECIATED. Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> X 2 on the diff lowering PICTURES and a write up would be fantastic <img src="/forums/images/graemlins/kewl.gif" alt="" /> Cheers, Chris <img src="/forums/images/graemlins/cheers.gif" alt="" />
