Smoking winch
Power steering pump leak.
replace master cylinder
Ignition Coil
Smoking winch
Gen 1 starting issue
by Oso - 04/01/21 05:28 AM
0 registered members (), 88 guests, and 6 spiders.
Topics138,201
Posts1,081,246
Gen 3 Speaker help #1057792 03/14/13 10:03 PM
brubren3815 Offline OP
My kids killed the sub-woofer in my XLS. I have gone to 3-4 stero stores to get it replaced. They want to put in a speaker that's the size of my tire!!! I just want to get it back to stock (or close). The Stealer showed me the parts diagram and it shows a 20w 20cm speaker. I'm guessing that that should be an 8" round? They want $123 for it.
Any guidance on this and, is it hard to replace??
Thanks!
2002 XLS /LSD/Thule Rack /PIAA Extreme White headlamps /K+N system/Michelin LTX MS--KYB gas-adjust all around
95 LS-- Dual Bouncy Seats 234k and still rockin'
Re: Gen 3 Speaker help [Re: brubren3815] #1057793 03/14/13 11:09 PM
off-roader Offline
Good question. Can you get a copy of the printout showing the speaker location along with how it's disasembled? Alternatively it's possible the 03 Factory Service Manual(FSM) has an illustration. Worth downloading from mitsubishilinks.com to check if it's there.
Then you can tell if it would be easy to replace.
HTH <img src="/forums/images/graemlins/kewl.gif" alt="" />
Off Roader
96SR Build Up Thread
Old web page
Old web page
Re: Gen 3 Speaker help [Re: brubren3815] #1057794 03/15/13 06:52 AM
Sabre Offline
My '01 Limited had a blown subwoofer speaker when I got it. You have to remove the plastic interior panel to get to it. It wasn't difficult, just a bit tedious. I didn't need a manual, although you can get the procedure easily enough by googling this. Basically, I had to remove the left side of the rear floor to get at the attachments for that panel. It was simply a matter of just following the fasteners and experimenting a bit.
The speaker itself had a torn cone. You could pull it out and then try to match a replacement, but mine was easily repaired and my fix has lasted several years with no problems.
I could tell you more, but suddenly I am run over by a truck.
-Michael O'Donoghue, "How to Write Good"
Be kind whenever possible. It is always possible.
-the Dalai Lama
PHP: 7.2.34 Page Time: 0.011s Queries: 15 (0.003s) Memory: 2.8300 MB (Peak: 3.1634 MB) Data Comp: Off Server Time: 2021-04-12 05:50:46 UTC
