2.6 balancer bolt
monty build thread
by motero - 11/30/21 07:57 PM
Happy Turkey Day
by motero - 11/30/21 07:45 PM
by motero - 11/22/21 08:28 PM
JK Check Engine Light - P0300
2.6 balancer bolt
monty build thread
Happy Turkey Day
1991 Diesel Swap
1 registered members (MarkG), 115 guests, and 3 spiders.
Topics138,250
Posts1,081,587
Members15,228
Page 2 of 6 1 2 3 4 5 6
Re: Suspension been fitted [Re: Peabody] #1058040 05/01/13 01:21 PM
4
4runnernomore Offline OP
Hi everyone,
Had my alignment done today so the Sporty now almost tracks straight <img src="/forums/images/graemlins/scared.gif" alt="" />
The company identified a couple of issues which need to be addressed.
For those running 4 inch lift what did you do about the angles your balljoints on the upper A arm are on. mine is basically maxed out and is pulling on the joint <img src="/forums/images/graemlins/ignore.gif" alt="" />. so the angle needs to be reduced.
also found out my steering box is flogged out with lots of fore and aft movement as well as left to right so I will have to replace the steering box as well soon. Not happy.
A few other little issues that aren't to bad with a couple more bushes, and sway bar rubbers perishing causing movement.
The steering idler has been replaced with a new Kia one but there is still movement in it. would this be related to the steering box having excess movement?
Also not to happy with the softness of the front struts and rear shocks. May need to still look into custom struts and shocks to get the firmer valving required. You can nearly get the front wheels to lift off the ground just by bouncing the front end by hand..
I have purchased a KMAC universal castor adjustment that still needs to be fitted at some stage once the angle of the upper ball joint has been sorted.
All ideas are welcomed.
so with these issues the Sporty is still nervous on the road which needs to addressed as my son will be learning how to drive in it.
cheers, Chris : <img src="/forums/images/graemlins/cheers.gif" alt="" /> :
Re: Suspension been fitted [Re: 4runnernomore] #1058041 05/01/13 09:31 PM
fokion Offline
For the Aarms you need to fab up something like the jeepbyal aarm for the KJs
as for the play... I got used to it after changing and changing and changing parts and max after six months allover again.
now I am only changing the halfbars...
my stearing box is even dripping.....
it took 2 years to get from max to min....
Re: Suspension been fitted [Re: fokion] #1058042 05/02/13 09:07 AM
4
hi Fokion,
hanks for the info <img src="/forums/images/graemlins/patriot.gif" alt="" />
The arms look the business, it is a matter of finding someone who will do this type of work for the Sporty.
more bloody research <img src="/forums/images/graemlins/angry.gif" alt="" />
Oh well, it has taken 6 years together to this stage <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Suspension been fitted [Re: 4runnernomore] #1058043 05/09/13 11:28 AM
fokion Offline
A different aproach for the A arms ( ok DONT look at the coilovers <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> )
Its a RALLY RAID racing SPORT from Hungary
if you have facebook look for "solyom team"
Re: Suspension been fitted [Re: 4runnernomore] #1058044 07/03/13 10:10 AM
4
[quote]Hi everyone,
Well surprise,surprise, <img src="/forums/images/graemlins/angry.gif" alt="" /> the castor adjustment won't fit. Sent them pictures and asked them which bolt it should replace.
The only way now to get camber adjustment is eccentric adjustable bushes in the upper A-Arms. <img src="/forums/images/graemlins/zombie.gif" alt="" />
considering the bushes are pressed in and can't be replaced on our A Arms here is hoping that SIDKID may have a fix with his new A-Arms. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Luckily the kit will fit my wife's Trajet so it's not wasted. <img src="/forums/images/graemlins/smile.gif" alt="" />
Cheers, Chris <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: finally new rubber [Re: 4runnernomore] #1058045 11/07/14 04:28 PM
4
Finally had new rubber fitted today.
sporty is looking AWSOME <img src="/forums/images/graemlins/evil.gif" alt="" />
Fitted Bridgestones new muddie D674 in a 245/75R16
Re: finally new rubber [Re: 4runnernomore] #1058046 11/14/14 10:05 AM
4
Front locker, free wheeling hubs and Ring and Pinions fitted finally. <img src="/forums/images/graemlins/zombie.gif" alt="" />
Very happy with how the Sporty drives now. <img src="/forums/images/graemlins/wink.gif" alt="" />
Extractors and ceramic coating. [Re: 4runnernomore] #1058047 08/06/15 11:37 AM
4
Well finally coughed up the coin to get myself some wild fire extractors for the Sporty.
They arrived a couple of weeks ago. I dropped them off at the ceramic coaters today. Should be ready late next week.
Now to start saving for a new mandrel bent custom exhaust <img src="/forums/images/graemlins/scared.gif" alt="" />
SAAS SPORTS STEERING WHEEL [Re: 4runnernomore] #1058048 08/09/15 12:02 PM
4
Finally fitted my SAAS sports steering wheel today. I think it looks great.
Realised I had no photos of the new tyres fitted.
Here you go.
[Linked Image]c
Cheers Chris
Re: SAAS SPORTS STEERING WHEEL [Re: 4runnernomore] #1058049 08/09/15 01:10 PM
bombardj1 Offline
I notice your Sporty dips on the right side, mine does this also, is it because of a bad body/frame bushings? I thought on mine it was because of the broken spring I had, but it is still there after the lift I just did.
PHP: 7.2.34 Page Time: 0.035s Queries: 18 (0.012s) Memory: 2.8978 MB (Peak: 3.1636 MB) Data Comp: Off Server Time: 2021-12-07 02:55:03 UTC
