123
guests, and 3
Topics138,201
Posts1,081,246
For Sale 1997 Montero LS w/Locker
#1059434
05/05/13 04:38 PM
I hate to let her go, but new job requires me to get a smaller car. only 20K miles on the new timing belt and water pump service................a $5,000 dealer service with paperwork at 178K miles. Currently has 205K miles. Montero LS For Sale
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: For Sale 1997 Montero LS w/Locker
[Re: Scottie2113]
#1059435
05/05/13 07:18 PM
Does that truck have the 24 valve 3.0 or the SOHC 3.5?
!!!!!!!!!!!!!WHAT ABOUT BOB!!!!!!!!!!!!!!!
[Re: PA_JERO]
#1059436
05/05/13 09:06 PM
It has the 3.5L V6 24 valve SOHC.
[Re: Scottie2113]
#1059437
05/05/13 11:58 PM
and it does not come with the ladder or the water can ....... so im out
[Re: mxmikie]
#1059438
05/06/13 03:45 PM
Scottie, I'm interested, and have a couple of ? You state generally rust free, could you elaborate. I see the timing belt , and additional maintenance has been performed, how about the valve stem seals? 3rd row seats? Also, what part of the stereo is non-functional?
Thanks. If you want to send a pm, or e-mail, let me know. Paul
98 Gen 2.5 05 Pontiac GTO 91 Corvette ZR-1 2011 Kia Sorento (wifey mobile) Clarkdale, AZ
[Re: monte3]
#1059439
05/07/13 04:47 AM
By generally rust free, I mean surface rust at worst. Most of its life has been in Florida (prior to me buying it) and then in Arizona, so mainly just normal surface rust you would expect from a vehicle of it's age. Body panels are all in good condition, but paint needs re-finishing on hood and left front fender.
Valve Stem Seals were NOT replaced, they are original with 205k miles. It does not smoke surprisingly. I have used mobil 1 synthetic engine oil since I owned at 70k miles, so I would imagine engine is in as best a shape inside as it could be with 205k miles on it.
As an LS model, there were no jump seats included.
It has factory Mitsu AM/FM Radio and tape deck up front that works just fine. I had installed a 12 disc pioneer CD Changer in the rear cargo area with an after market interface adapter and it worked for most of the years I had it. It also had an aux input I used to use for my iPod, but just within the last year, the interface adapter went bad ($80 part still available online) and I never replaced it. I have the paperwork on the adapter required to get it going again, but I have gone through two of them in about 8 years, so the adapters seem to only last a few years and then take a <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
In short, the tape deck and radio work fine, but my aux input and cd changer install is in-op due to a failed adapter module.
If you want to discuss more on the phone, PM me your number and I will give you a ring.
Hope this helps.
[Re: Scottie2113]
#1059440
05/07/13 06:54 PM
Thanks for the reply. Unfortunatly, I've got to have the third row. The seats not the problem, but the belts might be... Thanks again <img src="/forums/images/graemlins/cheers.gif" alt="" /> Good luck w/ the sale.
