0 registered members (), 62 guests, and 5 spiders.
Topics138,276
Posts1,081,745
Page 3 of 3 1 2 3
Re: 95LS 24v 3.0L Sudden Rough Idle? [Re: MrJeebs] #1060164 06/07/13 11:57 PM
off-roader Offline
The timing belt was done 4 weeks ago or about 1600 miles ago, when the oil pump was replaced due to a severe leak. It is a mitsubishi belt. I opted to replace it when the oil pooled in the cover under the crank pulley and contaminated the belt, which only had about 10,000 miles on it, which was done by Old Colt when he did a full front and top of engine service on her about a year or so ago. He did every pulley, seal, water pump, timing belt and tensioner, plugs, wires... you name it, he did it.
So I got the new used ecu in today, and it did not fix the problem. The truck acts like it wants to start now, but it sputters and pops and will not start. I tried pedal to the floor, light pedal, no pedal, all with no joy. It does make a bit of difference when a small amount of pedal is applied.
I am really distressed at this point. I am in a strange city with no transport. I have called a tow truck with a flatbed to take it to the local Meineke. The Meineke in my old town did the oil pump, so they should be able to share whatever records they have with the shop down here.
DuCal,
The ecus you linked me to are for a different truck, but thank you anyway. I appreciate the effort very much.
I recall new ECU's take time to learn the correct idle but I don't think it should run that poorly. You confirmed the new isc is still good right? the ecu and isc can make each other go bad. <img src="/forums/images/graemlins/frown.gif" alt="" />
Off Roader
96SR Build Up Thread
Old web page
Old web page
Re: 95LS 24v 3.0L Sudden Rough Idle? [Re: off-roader] #1060165 06/08/13 03:38 AM
MrJeebs Offline OP
[/quote] I recall new ECU's take time to learn the correct idle but I don't think it should run that poorly. You confirmed the new isc is still good right? the ecu and isc can make each other go bad. <img src="/forums/images/graemlins/frown.gif" alt="" /> [/quote]
No I didn't Offroader. I do not have any tools or place to check it. But the one I bought was from Autozone, and it came with a lifetime warranty, so I called them and told them the one I just bought was bad, and they will have a new one in the store at 8 am. I asked if she would refund me once I brought the "bad one" back, and she said she would. I rented a car, so I will go there first thing and get it, put it in the truck and see if that is indeed the problem. New IAC and new used ECU. I sure hope this does the trick. I was not aware they could make each other go bad, I thought only the IAC could ruin the ECU. Thank you for the heads up. It is much appreciated, as always, sir.
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 95LS 24v 3.0L Sudden Rough Idle? [Re: MrJeebs] #1060166 06/08/13 06:29 AM
off-roader Offline
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> [/quote]
No problem. One of the ecu rebuilders told me that.
Re: 95LS 24v 3.0L Sudden Rough Idle? [Re: off-roader] #1060167 06/08/13 03:50 PM
MrJeebs Offline OP
I got another IAC and installed it this morning. The truck started, but is missing very badly. It does idle, but again it is sputering and popping.
I let it run for a good 20 mins to let the new ecu learn what it needs to.
There is not, nor has there been, any CEL.
Is there anyway to tell the timing belt has jumped a tooth without tearing off the front of the motor, again? I am WO deri g if all of the popping and sputtering might have caused the belt to jump?
Sorry for typos and grammer, typing this on my phone.
Anything else you all can suggest before I get slapped with a repair bill I can't afford?
Re: 95LS 24v 3.0L Sudden Rough Idle? [Re: MrJeebs] #1060168 06/08/13 05:27 PM
fasteddy Offline
Not likely timing belt. The simple stuff first. Spark, fuel - likely spark...
Re: 95LS 24v 3.0L Sudden Rough Idle? [Re: fasteddy] #1060169 06/08/13 08:39 PM
MrJeebs Offline OP
I was thinking spark as well, as it did run, which means it's getting fuel.
I am not able to find the exact method for clearing the ECU. I have read to remove power from it over night, hold the + and - cables together for 10 seconds then reconnect to battery... Anyone know the right way to clear the 306993?
Old colt did wires and plugs, as well as new coil pack about a year ago. If you were to hazard a guess, what could have happened to the ignition system from all the cranking/sputtering and misfiring?
Any ideas I could give the tech at Meineke would sure be much appreciated, before he spends hours diagnosing and whacking me with a huge bill.
Re: 95LS 24v 3.0L Sudden Rough Idle? [Re: MrJeebs] #1060170 06/09/13 05:23 AM
DuCal Offline
Sorry brother I linked you to the 90 not the 95. I owe you one.
Seattle WA... (Everett)
1990 Montero LS OME complete, 2"BL,spray-paint.
1990 Montero LS in the 1st stage of rebuild.
2009 Pilot, Bone stock.
"Let me put on my slightly larger glasses".
Re: 95LS 24v 3.0L Sudden Rough Idle? [Re: MrJeebs] #1060171 06/10/13 02:06 AM
K
KrzyDav Offline
I was just grasping when I suggested slipped T belt. I didn't recall any of your previous post on what you've done,,,gettin senile I recon.
I hope Rockauto sent you the right Distributor. With the wrong one it probably wouldn't run at all. Harness coming out the bottom and it's an '89.
Yours being OBD2 I think your stuck with having codes read.
That's probably the only way to see if it's cam or crank sensor.
You have 3 coils , maybe as seperate packs,,,were all replaced? I don't know much about them, I don't know if each one has an igniter or if those are inside the ECU.
On gen 1 the ECU and ICS are reset after the battery cable has been disconted to clear codes and then reset by starting and ildling 5 min. , shut off restatr and ildle 5 more. Each time idle will drop about 100rpm till it gets to 700rpm. Keep in mind the Gen 1 is a hundred time more primative an ECU.
I would never touch the 2 cables together incase some juice was left in a capacitor somewhere.
dave h.
Re: 95LS 24v 3.0L Sudden Rough Idle? [Re: KrzyDav] #1060172 06/10/13 05:04 AM
MrJeebs Offline OP
No Worries, DuCal. I appreciate the effort very much.
Dave, my truck has a 1 piece coil set of 3 coils. They were replaced by Old Colt when he did the service on her a year or so ago.
The tech at Meineke told me Saturday that after much hassle and he got a code 41, which is Crank position sensor I believe. He said all kinds of numbers were way off, and that the timing was all fubar. All this is according to his Snap On Modus. Fuel pressure is good. He said he is going to diagnose it further before committing to tearing off the front of the engine, yet again. It has been taken down to the crank sensor 4 times in the last 2 years, most recently about 4 weeks ago before I made the trip down here. The sensor itself was replaced about 2 years ago, when a tech pinched the wires and ruined the sensor putting it back together.
As for OBD, my truck is 1.5, not 2, so it is still fairly primitive.
So I gfuess if the Snap On scanner can read the code, then the ECU must be ok? Or am i mistaken in that as well? LOL
As always gents, thanks ever so much for the replies.
Oh, I almost forgot, can anyone tell me the name of the stealer in TX that everyone orders from?
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: 95LS 24v 3.0L Sudden Rough Idle? [Re: MrJeebs] #1060173 06/10/13 05:09 AM
K
KrzyDav Offline
as I recall the dealer is called Southwest.
Maybe you still have some damage in the wires or connector on the cam sensor.
I think your codes are all a mess with everthing that's happened, unplugging stuff and such so your getting codes that are cause by secondary stuff and your problem is that cam sensor.
dave h.
Page 3 of 3 1 2 3
PHP: 7.4.30 Page Time: 0.030s Queries: 16 (0.011s) Memory: 2.9248 MB (Peak: 3.1931 MB) Data Comp: Off Server Time: 2022-07-05 00:13:38 UTC
