by polar - 01/14/21 08:42 PM
by polar - 01/14/21 08:40 PM
torsion bar question
Vet over his Head
by tcb762 - 01/12/21 11:02 PM
by code33 - 01/03/21 03:52 AM
Vet over his Head
Posts1,080,940
Page 2 of 2 1 2
Re: Gen1 2.6 no idle! [Re: Mad_Scientist] #1063467 10/28/13 01:16 AM
ryany Offline
The Weber is a much simpler carb, has far fewer parts to fail or cause problems, and might give you a small performance boost over what the factory carb is capable of. If you don't have to worry about a visual emissions inspection then that would be my choice.
95 Montero SR 3.5
Re: Gen1 2.6 no idle! [Re: Mad_Scientist] #1063468 10/28/13 02:28 AM
geocrasher Offline
Might be a bit late, but have you plugged the line that goes to the charcoal canister? I've forgotten what its called but that valve goes bad and causes it to hardly run. BTDT.
And, Weber.
1987 Raider, 346K miles and going strong -31" tires, otherwise stock.
http://tidbitsfortechs.com/
http://actionpcs.com <-- $39 remote PC repair, guaranteed.
How to include pictures in threads on 4x4wire (Youtube video)
Re: Gen1 2.6 no idle! [Re: geocrasher] #1063469 10/28/13 02:53 AM
fasteddy Offline
Yes, the infamous bowl vent valve failure. Try that first.
Re: Gen1 2.6 no idle! [Re: fasteddy] #1063470 10/28/13 03:21 AM
geocrasher Offline
Bowl vent valve. Eddy beat me to it of course but while I was working it popped in my head! Yeah try that. Locate the big hose coming from the carb and meeting up with a hard line above the exhaust manifold area. Plug it (I used a drill bit lol!) and give your truck a spin.
Before I did that, my truck would have bouts of being powerless, like it wasn't getting fuel. It would cough and sputter and sneeze. Plugged that > new truck. Still need to re-carb it with a weber, but it drives fine now.
Re: Gen1 2.6 no idle! [Re: geocrasher] #1063471 11/04/13 02:15 PM
Mad_Scientist Offline OP
Nope, not that.
However, upon further inspection I noticed a hole in the intake. I thought, that's not right. Looked at the engine in my garage and hey presto! Swamped the part, fired it up and it runs a treated! <img src="/forums/images/graemlins/kewl.gif" alt="" /> I plugged the vacuum line because I guess it goes to the stock air cleaner assembly? It turns out that the twit who put the aftermarket air cleaner on plugged the hole with a rubber bung that must have popped out! I will put a sock air cleaner on at some point. My guess is that works much better.
Thanks for all the help <img src="/forums/images/graemlins/cheers.gif" alt="" /> I learned a lot as always <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Gen1 2.6 no idle! [Re: Mad_Scientist] #1063472 11/04/13 05:54 PM
OK, the power sucks. I know it's no powerhouse, but this is bad. I lost all the carb settings messing about with it. However, I set the timing and idle speed. Then I adjusted the mixture screw to the highest rpm and then reset the idles speed and checked the timing. This is what the FSM appeared to describe.
Assuming I am starting from scratch, how do I set the carb up? Ejumicate me <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: Gen1 2.6 no idle! [Re: Mad_Scientist] #1063473 11/04/13 08:49 PM
fasteddy Offline
That's about all you can do. Is the choke opening when warm? Test the secondary butterfly vac can by pulling off the hose and see if the can holds vac. I put on an extending hose and suck on it and see if the vac holds.
Page 2 of 2 1 2
PHP: 7.2.34 Page Time: 0.030s Queries: 16 (0.009s) Memory: 2.8748 MB (Peak: 3.1634 MB) Data Comp: Off Server Time: 2021-01-20 14:12:48 UTC
