the cold start shuffle got me
0 registered members (), 61 guests, and 6 spiders.
Topics138,274
Posts1,081,733
3RZ - New t-stat, Now high idle.. #1066329 11/18/13 05:18 PM
Staceman Offline OP
Suggestions?? Idle will not go below 1500RPM regardless of engine temp. As if cold-idle is stuck. All I did was replace the thermostat... Burped with heater on, no vac leaks, stumped... Ideas?? (I am new to this 2.7 motor) Thanks!
Re: 3RZ - New t-stat, Now high idle.. [Re: Staceman] #1066330 11/19/13 08:36 AM
kewlynx Offline
Coolant sensor might be freaking out and not seeing the coolant come up to temp. Did you test the new t'stat in some hot water before you put it in?
Make sure the t'body linkage is clean.
**ubi apis- ibi salus**
Re: 3RZ - New t-stat, Now high idle.. [Re: kewlynx] #1066331 11/19/13 04:13 PM
Staceman Offline OP
Thanks for the reply Margie. I did test the t-stat actually.. First time. I found a suggestion repeated through various boards. I disconnectd the battery while at work all day. Reconnected it. Within 10 miles, the idle is perfect now after warming up. Removing just the EFI fuse for awhile seemed to do nothing. Either way, this little truck is back to 100%. Thanks!
Moderated by  4x4Wire, Dandeman, kewlynx
PHP: 7.4.29 Page Time: 0.023s Queries: 15 (0.008s) Memory: 2.8627 MB (Peak: 3.1930 MB) Data Comp: Off Server Time: 2022-05-26 17:55:47 UTC
