the cold start shuffle got me
0 registered members (), 74 guests, and 3 spiders.
Topics138,274
Posts1,081,733
PLUS: installed new front calipers and pads. MINUS: rear door handle's broke #1068449 01/26/14 05:35 AM
off-roader Offline OP
New front calipers went in without a hitch. Replaced the old pads as well then fully bled the front brake lines.
Unfortunately however the rear door handle broke and it's not opening from the inside.
Will have to remove the rear sleeping platform to access the rear door and pull the panel so I can open it. <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/angry.gif" alt="" />
Off Roader
96SR Build Up Thread
Old web page
Old web page
Re: PLUS: installed new front calipers and pads. MINUS: rear door handle's broke [Re: off-roader] #1068450 01/26/14 03:42 PM
plh Offline
The rear on my '92 broke last summer, so when I got the '93 I removed the door panel and lubed the mechanism with white lithium. Did an inspection and it looked like old plastic (21 yo), anyways, broke a couple mornings ago at 0 deg F, but not the finger that sticks into the mechanism, this time the handle portion under the outside cover just split apart.
Ordered this replacement:
http://www.amazon.com/MITSUBISHI-MR230032-MB669338-ORIGINAL-TAILGATE/dp/B00DKOKYMC
$56 shipped. Same one I ordered last summer for the '92.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: PLUS: installed new front calipers and pads. MINUS: rear door handle's broke [Re: plh] #1068451 01/26/14 11:51 PM
TOASTY Offline
I replaced mine 9 years ago and it lasted 7 years, when it broke again i rebuilt it out of steel. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: PLUS: installed new front calipers and pads. MINUS: rear door handle's broke [Re: TOASTY] #1068452 01/27/14 03:41 AM
Is it like the OEM unit but in steel? I'll buy if you're still making them...
Off Roader
Old web page
Old web page
Re: PLUS: installed new front calipers and pads. MINUS: rear door handle's broke [Re: off-roader] #1068453 01/27/14 01:18 PM
plh Offline
Steel - that is a super good idea!
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: PLUS: installed new front calipers and pads. MINUS: rear door handle's broke [Re: off-roader] #1068454 01/27/14 04:52 PM
Struc Offline
Take any pictures?
Curt Shambeau
Re: PLUS: installed new front calipers and pads. MINUS: rear door handle's broke [Re: Struc] #1068455 01/27/14 06:23 PM
TOASTY Offline
No pics, if this is something you dudes want i'll come up with a way to mass produce. Give me a minute, what's the magic number i need to beat cost wise? I'm guessing i need to be competitive with the replacement plastic part. The main ingredient here are the sides of the handle, they are a specific shape. if i can get those cut out in a non time consuming way the rest is easy. Stay tuned.
Re: PLUS: installed new front calipers and pads. MINUS: rear door handle's broke [Re: TOASTY] #1068456 02/02/14 04:33 AM
Paul, thanks again for the lead on that part on ebay. I got it on Friday after ordering it las Sunday! Not bad considering it came from FL and was shipped USPS!
Def still interested although I won't be needing it right away LOL...
With Michael's help I installed the replacement OEM handle today!
It was a bit of a challenge because I wasn't able to open the rear door at all since the rear latch was broken and my internal door latch was also not working. Plus my sleeping platform prevented me from removing the internal panels to access the door latch mechanism.
So what we did is open the door from the outside latch using an Allen wrench! As you can see in the pic below...
... the plastic latch mechanism pushes down on an internal metal latch (mike's left index finger is pressing on it). That metal latch actuates a mechanism that opens the door.
Here's how we used an Allen wrench to push down on that latch from outside the door...
Here's kinda what it would look like as you did it from the outside... Except you probably won't see mike concentrating so intently on the process <img src="/forums/images/graemlins/wink.gif" alt="" />
All in all, it only took a minute or so to get the door open once we figured out how to open it.
Then once opened, it was a simple R&R process to replace the broken door handle. <img src="/forums/images/graemlins/kewl.gif" alt="" />
In addition, I also removed the shocks from Carlos' rig since they're fresher than mine which have started to go out. I'll have to install them on a different day though when I have more time. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
As usual, special thanks to Mike for helping me out and really doing the bulk of the work! <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: PLUS: installed new front calipers and pads. MINUS: rear door handle's broke [Re: off-roader] #1068457 02/02/14 03:41 PM
plh Offline
Mine arrived on yesterday (Saturday) going to install today. Sunny - but for sure no short sleeves. 8F (-13C) :-)
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: PLUS: installed new front calipers and pads. MINUS: rear door handle's broke [Re: plh] #1068458 02/02/14 04:44 PM
Nothing like that balmy Great Lakes winter weather you always have <img src="/forums/images/graemlins/wink.gif" alt="" />
Hopefully you'll be doing this in a heated garage. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Check ur PM's btw...
Off Roader
Old web page
Old web page
PHP: 7.4.29 Page Time: 0.031s Queries: 16 (0.009s) Memory: 2.9327 MB (Peak: 3.1935 MB) Data Comp: Off Server Time: 2022-05-27 01:00:22 UTC
