LED Headlights
The End is Near
LED Headlights
The End is Near
Topics138,278
Posts1,081,771
Transfercase wiring #1070768 04/09/14 07:20 PM
spencevans Offline OP
I am trying to install the 4wd switches on my 1983 Mitsubishi Pickup. The wires for the switches that are in the vehicle are broken off and are of no use. I need to know how to wire the two 4wd switches. Pictures would be helpful.
Spence
1985 Mitsubishi PU 2.3 Turbo Diesel, 13" lift, Watercooled turbo, 4D56 Head, Atlas II,Fox Coilovers, Elockers,
1983 Mitsubishi PU 2.5 Turbo Diesel 4x4, fully restored
2003 G500, sliders, beadlocks, roofrack, ladder etc.
Re: Transfercase wiring [Re: spencevans] #1070769 04/10/14 12:08 AM
fasteddy Offline
The best I could do is the 84 monty manual on mitsubishilinks.com. You have two switches? With 4 wires? That model has really cruddy wiring diagrams. The switches are on the rear extension housing, aft of the chain case. The most forward is probably the 4wd switch, and the rearmost is the lorange, judging from how the rail moves as the shifter moves (shifter moves forward, rail moves back). Two wires for each switch. Two of the 4 should show 12v+ with the ign on. One of these to each switch. The other two go to the indicator lights, and you'll have to experiment to see for sure which switch lights which light when the shifter is moved into each notch. Happy wiring...
Re: Transfercase wiring [Re: fasteddy] #1070770 04/10/14 06:10 AM
I was able to find my 1985 wiring diagram. I had two switches with 2 wire each for a total of 4 wires. It wired the two switches together and the other 2 wires I wired to the Tcase harness. Presto, it worked on the first try. I also replaced my 4wd light on the dash with an LED light. It made a big difference. Now I can see it illuminate in the day time. God bless LED lights.
Spence
Re: Transfercase wiring [Re: spencevans] #1070771 04/10/14 02:17 PM
Mudraider Offline
Been contemplating the LED bulbs. Good info!
Re: Transfercase wiring [Re: Mudraider] #1070772 04/14/14 06:17 AM
The LED lights for the cluster are a no brainer. They are cheap and easy to install. I bout the green Zone Tech LED light off of Amazon. I got 10 LED lights for under 10 dollars.
Spence
PHP: 7.4.30 Page Time: 0.025s Queries: 15 (0.009s) Memory: 2.8756 MB (Peak: 3.1929 MB) Data Comp: Off Server Time: 2022-08-09 10:46:31 UTC
