the cold start shuffle got me
0 registered members (), 64 guests, and 1 spider.
Topics138,274
Posts1,081,733
No Low Beams #1072781 07/03/14 10:55 PM
fasteddy Offline OP
Swapped H/L relay, no joy.
That means column switch, right. Only place the two have in common is there, and it controls the final part of the ground circuit for the lo or hi beam circuit, one always grounded. Hmmm, I could install another switch, grounding the lo beams, and they would be on whenever the headlight relay provided power to the center terminals on the lights. The switch would only be used when you wanted to run high beams only, otherwise you'd be in lo beam, or low and high beam, which is not a bad idea anyway...
I hate taking the column apart...
Re: No Low Beams [Re: fasteddy] #1072782 07/03/14 11:50 PM
As long as you have no CC or headlight washers, I have a combo switch extra. Let me know via PM if you need it.
Re: No Low Beams [Re: rxinhed] #1072783 07/04/14 01:53 AM
fasteddy Offline OP
it has cruise and HL washers, but thanks anyway. I'm going to try the add-a-ground...
PHP: 7.4.29 Page Time: 0.025s Queries: 15 (0.008s) Memory: 2.8620 MB (Peak: 3.1928 MB) Data Comp: Off Server Time: 2022-05-27 16:26:03 UTC
