60
Tow hitch for dodge raider
#1073908
08/24/14 05:55 PM
Hey guys, I'm looking into ordering a tow hitch for my raider, I see they make a class I plate style hitch as well as a class II that's a different style. I'll be towing a motorcycle trailer with only one motorcycle on it, as well as a boat trailer with only a 15' fiberglass boat on it. Which class hitch would be more appropriate?
Re: Tow hitch for dodge raider
[Re: mfarmer10]
#1073909
08/24/14 06:10 PM
What year Raider? The simple Class I hitch will only be rated for 1,000 pounds. Class II is a higher rating. Link to another 4x4Wire thread with good technical discussion and pics: 4x4Wire Thread
[Re: rxinhed]
#1073910
08/24/14 06:22 PM
[Re: mfarmer10]
#1073911
08/24/14 08:56 PM
I have the same one Russ has, from a 4-door truck . It works excellently. I had to fab up some extension pieces for where the outer attaches, but it works 100% better than all those others. If'n you can find one off of a 4-door I highly recommend it.
[Re: Mudraider]
#1073912
08/25/14 08:06 PM
The hitch I settled on is a 4-door hitch that is welded on, took a bit of trimming for the wings...but all worked out well.
[Re: rxinhed]
#1073913
08/28/14 03:35 AM
I got one that bolts to the frame siting in my basement
[Re: RECON45]
#1073914
08/28/14 07:58 PM
I have used a Curt 4-bolt hitch that just bolts up to the factory bolt holes to pull a pretty big pop-up camper up into the mountains and down dirt roads for camping, as well as pulling a dual-axle trailer with a bunch of furniture on it for a couple of hundred miles with no issues. The pop-up was heavy enough to warrant the use of a trailer brake control, which I really liked, but you do have to have a 7-wire connection and the appropriate interior wiring and a brake controller for that.
And yes, I know, I probably shouldn't be doing these things with such a light duty hitch, but I thought I'd throw the idea out there.
John B.
'87 Raider 2.6 Turbo Auto, Under Construction '95 Montero SR, 35x12.5/15 BFG M/T KM-2's, Rock sliders, Qtr panel chop, gas tank lift, 2" BL, Aisins, 5.29s '95 Pajero Mini '98 Montero Winter Ed. '04 Cadillac XLR '03 Kawasaki ZRX1200R '60 Ford Falcon 4Dr
[Re: RECON45]
#1073915
08/29/14 07:43 PM
I have a 4-bolt on my 89 SWB. I normally pull a purpose built (camping) 4X8 trailer with electric brakes. No problems. I have towed lots more (very carefully).
I had a bolt on stage 3 for the LWB. It disappeared while I was living out of the country. It looked like it would install easily with a little angle grinder modification.
I had a Gen2 SWB (heavier) in Australia with the 4-bolt hitch. A professional car hauler said it was certified to 750kg (1650 lbs). He also said the SWB should not tow more regardless of hitch.
I have towed more with my '89, but very carefully.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
