93
Topics138,278
Posts1,081,771
So 1990 Tranny has over 300k, Do I service it? And where to get speedo cable?
#1073981
08/29/14 04:00 AM
Tranny last serviced at 200K. Truck refuses to die! Just put new flasher in for actual working turn signals and fixed the horn. So do I dare to have it serviced? My friend who owns a shop is kinda afraid to touch it with that many miles.
Next- where can I get a speedo cable?
1990 Black Monty LS Over 300K' 1993 Isuzu Rodeo LS 4x4 46k (yes only 46K!)1989 Honda Transalp 600 Africa twin,
Re: So 1990 Tranny has over 300k, Do I service it? And where to get speedo cable?
[Re: sasnydley]
#1073982
08/29/14 05:47 AM
Servicing consists only of draining the old fluid and cleaning or replacing the filter screen and then replacing the fluid. I would NOT flush the tranny under any circumstances. To do so stirs up old ghosts that are better left sleeping. I would only use the special Mitsu fluid. There is plenty of anecdotal evidence that Dexron just is not as good.
I would try rockauto for the cable. If that fails, I'd try to find a real speedo repair shop and get them to reuse the ends and make a whold new cable.
[Re: fasteddy]
#1073983
08/29/14 07:03 PM
I may have one you can have...
[Re: TOASTY]
#1073984
08/31/14 12:46 AM
I may have one you can have... PM sent
[Re: fasteddy]
#1073985
08/31/14 12:52 AM
Servicing consists only of draining the old fluid and cleaning or replacing the filter screen and then replacing the fluid. I would NOT flush the tranny under any circumstances. To do so stirs up old ghosts that are better left sleeping. I would only use the special Mitsu fluid. There is plenty of anecdotal evidence that Dexron just is not as good.I would try rockauto for the cable. If that fails, I'd try to find a real speedo repair shop and get them to reuse the ends and make a whold new cable. MITSUBISHI Diamond right? He tends to use the brand Red line I think. But he can get the Mitsu stuff. He is worried that if he does this that it won't even drive off the rack... Issue with Rock Auto is I can't find the cable. I did find a Mitsu parts dealer that has it- but not 100% sure. .
[Re: sasnydley]
#1073986
08/31/14 03:50 AM
To find the speedo cable on rockauto, look under Body-Interior. That's where they have it listed for the '87 Raider. It's next on my parts list.
On a side note... I miss my '94 Rodeo LS 4x4. Some idiot turned left in front of me and that was it.
1987 Dodge Raider, 2.6L, manuel, bone stock with a whole lot of new and refurbished parts. Brought back from the dead after 12yrs.
[Re: AZRaider]
#1073987
08/31/14 09:13 PM
On a side note... I miss my '94 Rodeo LS 4x4. Some idiot turned left in front of me and that was it. Body interior LOL! Thanks! I will post up some pics of my rodeo this week when I get a chance to clean it.
[Re: sasnydley]
#1073988
09/02/14 09:21 AM
No Prob. Glad I could help. Hopefully the info is useful to others. And you're gonna make me jealous. Lol
[Re: AZRaider]
#1073989
09/02/14 08:14 PM
[Re: sasnydley]
#1073990
09/02/14 10:33 PM
What is wrong with the speedo cable? If the outer housing is fine, you can replace only the core square cable thing, which just slips out. If it's just a twitchy needle, you can pull out the old core and relube it and reinsert (I've used an electric drill on slow to put the core back in, wiping on lube as it inserts in the housing.
