108
Topics138,202
Posts1,081,253
Which ACT clutch?
#1074031
08/31/14 01:17 PM
I could have sworn there was a thread here regarding which ACT clutch & pressure plate is best but after a lengthy search I didn't find it.
Re: Which ACT clutch?
[Re: promodmerc]
#1074032
08/31/14 09:53 PM
Must have been erased. I did a search and came up with nothing as well... But, on the innertubes (net) I found this; ACT clutch kit for sporty
[Re: DRX350]
#1074033
09/02/14 11:01 AM
Hey Guys, I ordered a clutch from SOUTHBEND CLUTCH and the pressure plate gave a much heavier pedal than stock and had it come with a kevlar clutch. Well, I think the kevlar doesn't like the slippage I have to do cause of my 32" tires so I am going back to a organic Exedy disc.
Hope this helps. Everet
[Re: Everet]
#1074034
09/02/14 07:29 PM
How much does the tranny/transfer case weigh? A friend of mine knows someone that might be able to help with replacing it but needs to know an idea of the weight.
I believe the ACT clutch I'm looking at is organic. A 235/75/15 or 30x9.50x15 is the largest tire I will be running.
