67
guests, and 4
Posts1,081,743
STAINLESS STEEL BOLTS & LOCKWASHERS FOR LOCKING HUBS
#1075207
11/16/14 05:44 PM
![[Linked Image]](http://i121.photobucket.com/albums/o214/evlu/100_4902.jpg) This bolt kit will replace your existing rusted or broken bolts on your front hubs. Remove your old bolts, replace with these new stainless steel bolts and washers. Just add antisieze! Never worry about snapping another bolt due to rust. Makes front hub maintenance easier. Just pm me or email me at: everet@upyourkia.com Everet
Re: STAINLESS STEEL BOLTS & LOCKWASHERS FOR LOCKING HUBS
[Re: Everet]
#1075208
11/18/14 11:28 AM
Hi Everet,
kit looks great,
Do they fit all brands of free wheeling hubs. (Warn,AVM etc)
Can you please let everyone know what it will fit.
Not quite inthe market yet as I have only just had my AVM hubs fitted with the front difflock and 5.38 ring and pinion install.
Keep up the good work. : <img src="/forums/images/graemlins/patriot.gif" alt="" />
On another note, any updates on your other suspension products?
I don't have face book so can't view your Facebook sight for additional info and updates.
[Re: 4runnernomore]
#1075209
11/19/14 02:41 PM
These are direct replacements for stock bolts. I know they work with Warn hubs and stock hubs. If you used your stock bolts, then these will work.
Nothing new planned for the rest of this year.
Everet
[Re: Everet]
#1075210
11/22/14 07:38 AM
Everet,
Cool kit. I might need to get a set because I just had to replace a Warn hub due to the bolts freezing into the hub and I had to cut it off. Took it in for a state inspection last year and the dork who checked and repacked my front bearings did not put new anti-seize on the bolts when he put it back together. What a pain!
