83
guests, and 4
Posts1,080,941
88 conquest LSD (SOLD)
#1076416
01/22/15 08:16 PM
HI Everyone, I have a starion/conquest 1988 LSD up for sale. I have 4.62 gears for it as well. It was used in my rear axle 87 swb. Email or PM on a reasonable offer.
Thanks,
Jason
Re: 88 conquest LSD
[Re: 87monty]
#1076417
01/23/15 03:42 AM
Is this a rear from a truck or the rear from a conquest (front truck potential)?
- 88 Raider: 5 spd, 4.62 LSD F & R, T/L, OME Rear Springs, KYB G/A, 33/12.5/15" MTZs, PLH LOs, Justice Bumper, Dual Bouncies, 4D56T in -running soon!
- 1992 RS M/T
- 1993 SR
- 2005 Montero LTD
- Gen 1 - PARTS FOR SALE
- http://www.tuffpans.com
Re: 88 conquest LSD
[Re: plh]
#1076418
01/23/15 04:19 AM
The rear from a conquest 8" will work in V6 front.
Re: 88 conquest LSD
[Re: 87monty]
#1076419
01/24/15 03:49 AM
its an 8" that came out of my rear axle 87 swb. I'm so confused...came out of your REAR swb - montero? Therefore NOT from the rear of a conquest ? please clerify
- 1992 RS M/T
- 1993 SR
- 2005 Montero LTD
Re: 88 conquest LSD
[Re: plh]
#1076420
01/24/15 05:29 AM
No confusion needed. The 8" rear diff LSD from the Starquest, Montero, and Mighty Max / D50 = same part. And, yes, can be used in the front 8" diff found on Gen I V6 Montero and MM.
J...is this the Madera McDonald's unit? If so, was sourced from an 87 Raider I had.
Re: 88 conquest LSD
[Re: rxinhed]
#1076421
01/25/15 05:56 PM
J...is this the Madera McDonald's unit? If so, was sourced from an 87 Raider I had. Thanks Russ, and yes sir same awesome unit. With 4.62 gears if needed.
Re: 88 conquest LSD
[Re: 87monty]
#1076422
01/26/15 02:13 AM
Read a long time back on the WIRE: the truck rear carrier is slightly wider than the car and therefore doesn't fit in a truck front. That is why there was such an "AH HA" moment when the Starion/Conquest rears were found to fit the front of the trucks. Hey the search function only goes back 5 years whats with that? I dug back almost 6 years when I did my first front Gen 1 LSD swap. Info in that thread says for sure its a NO/GO. Too wide, wrong splines. I've never verified personally however. Here is the thread: web page
- 1992 RS M/T
- 1993 SR
- 2005 Montero LTD
Re: 88 conquest LSD
[Re: plh]
#1076423
01/28/15 01:08 AM
Re: 88 conquest LSD
[Re: 87monty]
#1076424
02/07/15 01:04 AM
Id like to buy. How does $150 sound?
