by rascott - 05/17/21 03:54 AM
1988 Raider G54B Rebuild Mistake?
by Spduffee - 05/16/21 08:25 PM
1987 Raider Brakes
by Gnarlon - 05/14/21 06:32 PM
Weber Carb Unknown Parts
by Spduffee - 05/14/21 03:13 AM
Montero Ranch Land Anchors
by rxinhed - 05/12/21 11:00 PM
New Forum Opportunities - Request them here
by katherine67 - 05/12/21 09:39 AM
Gordie the Galloper?
by bill_bly_ca - 05/11/21 09:47 PM
by Spduffee - 05/13/21 08:29 PM
1987 Raider Brakes
by Gnarlon - 05/09/21 03:19 AM
Isolators for cross member and transfer case
by Rader1 - 05/05/21 02:52 PM
by rxinhed - 04/27/21 03:43 AM
helicoils and brakes
by rascott - 04/24/21 11:52 PM
0 registered members (), 199 guests, and 3 spiders.
Topics138,213
Posts1,081,321
Members15,189
Page 5 of 7 1 2 3 4 5 6 7
Re: NOT AGAIN !!! Hi it has been a while. Now Head gasket issue 90 LWB [Re: Jay Ayala] #1077396 06/27/15 09:04 PM
Jay Ayala Offline
Oh yeah, Javier, I've meant to tell you this for a while but I keep forgetting. Thanks for the bottle opener. I appreciate it.
Re: NOT AGAIN !!! Hi it has been a while. Now Head gasket issue 90 LWB [Re: Jay Ayala] #1077397 06/29/15 06:16 PM
JAVYPRO Offline OP
Oh men, no problem at all; thank you for our help.
I am on vacation until tomorrow so today I am taking this thing apart to see what happened. I already talked to the guy at the machine shop and he will check the heads for me.
Javy
Re: NOT AGAIN !!! Hi it has been a while. Now Head gasket issue 90 LWB [Re: JAVYPRO] #1077398 06/29/15 08:03 PM
JAVYPRO Offline OP
OK, I emptied the radiator and the first half of the coolant showed some discoloration but no oil was present.
I then drained some more and about the last 2 cups did show oil.
Like I mentioned before, could it be that the extra quart of oil that I put in the engine somehow found it's way to the cooling system via the intake? The engine never smoked burning that extra oil. Hmmmmm
Yes, I hate to take this thing apart again.
Javy
Re: NOT AGAIN !!! Hi it has been a while. Now Head gasket issue 90 LWB [Re: JAVYPRO] #1077399 06/30/15 08:28 PM
Jay Ayala Offline
Javier,
Those are two separate and independent closed systems. There should be no WAY that they should cross contaminate that way. The only two ways I can think of that oil got into your coolant is #1 that the head gasket was not fully torqued and the head surface has warped. #2 The other way oil could get into coolant is human error, by pouring oil directly into the radiator.
Re: NOT AGAIN !!! Hi it has been a while. Now Head gasket issue 90 LWB [Re: JAVYPRO] #1077400 07/02/15 06:10 AM
K
KrzyDav Offline
Sorry to hear,,,,heads on these are so frustrating. <img src="/forums/images/graemlins/frown.gif" alt="" />. Vent/cry all you want,,,folks on here have sure provided a shoulder to me during my head gasket/over shaved head ordeal over the past 3 years.
dave h.
Re: NOT AGAIN !!! Hi it has been a while. Now Head gasket issue 90 LWB [Re: KrzyDav] #1077401 07/23/15 05:11 PM
JAVYPRO Offline OP
Ok guys,
Tearing the engine apart one more time. Got new head gaskets and will order new head bolts, again. I wish I had all the lifters to replace them now that I am in there but this engine was quite and smooth so I guess I will not do it for now.
In the meantime Jacobo the red SWB with almost 500K miles is saving the day. That little machine saved my life once and now continue to save the day when the others need some time off.
I will post updates, I hope it doesn't take long as this is the 3rd time I take it apart.
Javy
Re: NOT AGAIN !!! Hi it has been a while. Now Head gasket issue 90 LWB [Re: JAVYPRO] #1077402 07/23/15 10:30 PM
JAVYPRO Offline OP
Took me just 4 hours to tear it apart plus +/- 10 minutes to take them to the machine shop.
They are going to pressure test them to see if they are cracked or bent.
Got to wait, if they are unrepairable, I found them at Rockauto for $339 so lets see.
Javy
Re: NOT AGAIN !!! Hi it has been a while. Now Head gasket issue 90 LWB [Re: JAVYPRO] #1077403 07/28/15 06:31 PM
off-roader Offline
NOTE: moderator, is there a way to reduce the size of the photo on the previous note? I got to find a way to post my pics, MSN seems not to be working.
Fixed it! <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Off Roader
96SR Build Up Thread
Old web page
Old web page
Re: NOT AGAIN !!! Hi it has been a while. Now Head gasket issue 90 LWB [Re: off-roader] #1077404 08/12/15 01:18 PM
JAVYPRO Offline OP
Thanks offroader.
Issue with the heads fixed <img src="/forums/images/graemlins/kewl.gif" alt="" />.
My friend at the machine shop found that I had drilled a little too far into the water jacket when drilling out the broken rocker bolt <img src="/forums/images/graemlins/scared.gif" alt="" /> No biggie, it was putting just a bit of oil into the coolant so he welded it up and since the heads were off he also cut them a bit to make them perfectly flat and have a clean seal surface plus cleaned the exhaust a bit.
It is evident that this has affected the heads performance in a positive way as this engine has come alive. It is not the same engine to which you will give it the beans and you will wait for it to respond No, no, no this thing goes.
It has to be all the little things, I am not building a screamer but little things help in a big way sometimes so others might come.
Javy
Re: NOT AGAIN !!! Hi it has been a while. Now Head gasket issue 90 LWB [Re: JAVYPRO] #1077405 08/17/15 07:16 AM
Jay Ayala Offline
Great News JavyPro!!!
I was wondering what had happened. It's a good reminder to all of us that we should be very diligent while extracting broken bolts on cylinder heads.
PHP: 7.2.34 Page Time: 0.040s Queries: 16 (0.015s) Memory: 2.8965 MB (Peak: 3.1642 MB) Data Comp: Off Server Time: 2021-05-17 12:02:15 UTC
