by Trailmonkey - 07/23/21 11:01 PM
Locked IFS bad or not ?
by Trailmonkey - 07/20/21 09:35 PM
High-quality Car Audio and Stereo Installation - C
by hazy_daze - 07/20/21 12:06 AM
by OldColt - 07/18/21 09:43 AM
Oil Pressure Sending Unit Part # ??
by 87CanadianRaider - 07/10/21 07:01 PM
Weber 32/36 air filter modification.
by 87CanadianRaider - 07/10/21 06:57 PM
by rxinhed - 07/10/21 02:30 AM
Anybody got a Montero/Raider Rig To Sale??
by polar - 07/03/21 08:44 PM
by Mudraider - 07/02/21 03:44 PM
Florida event - Wheeling and Racing September 25-2
by Mudraider - 07/02/21 02:44 PM
by polar - 06/27/21 07:35 PM
Ranch trip 6-26 - - FREE Parts
by rxinhed - 06/19/21 05:18 AM
0 registered members (), 127 guests, and 4 spiders.
Topics138,225
Posts1,081,422
Members15,204
Rear axle leak #1077603 04/07/15 06:55 PM
danz91crx Offline OP
I have a leak coming from a few spots on my rear axle. This is on a 90 lwb montero with a 3.0 and a/t.
One leak is at the pinion and I believe was from a bad U joint/vibration breaking the seal.
The other leak appears to be from the small off center hole in the axle shaft as pictured here
I was hoping someone with experience taking the rear axle apart could shed light on the leak coming from that hole. I am hoping to remove the rear end and change some bearings and seals when the weather warms up and I can use my bike to commute or I get time off from work.
1990 LWB RS A/T
1990 LWB Base A/T
Re: Rear axle leak [Re: danz91crx] #1077604 04/08/15 02:26 AM
H
haztoys Offline
Is your rear end vent plugged ...?
The rear 'axle bearings' on a Mitzu axle shafts are packed grease as a front wheel bearing would be ... Rear axles meet at a block in the diff/lsd...Rear axle shafts are shimed ... You have a seal at the end of the axle housing to keep the 90w oil out of the greased axle bearing ... And said seal is DOA ...
Have fun
Captain Gear Box
Hazardous Toys inc
Re: Rear axle leak [Re: haztoys] #1077605 04/08/15 06:42 AM
No, the vent is clear.
I tried to remove the axle shaft on the side that leaks when I changed my pinion seal last time. I don't know if you remember but you had suggested I use a chain next time to pull the axle. Still haven't done it yet.
Both the inner and outer seals go in the tube from the axle sides?
Thank you
1990 LWB RS A/T
1990 LWB Base A/T
Re: Rear axle leak [Re: danz91crx] #1077606 04/08/15 07:33 PM
H
haztoys Offline
Thank you
No theres a inner seal at the end of the axle housing ..That keeps the 90w oil in the diff ... That's bad replace the inner seal ... The axle shaft is made to piss 90w out that hole if the seals dies ... The outter axle seal you would have to replace as in press off the axle bearing to get to the out axle seal ... Replace the inner seals ... Clean and repack the axle bearings and run it ... The outter seals don't go bad ... Check your axle 'end play' before you remove the axles ...
Re: Rear axle leak [Re: haztoys] #1077607 04/09/15 07:40 AM
Thanks for the info. Your help and the FSM gave me a better understanding. I have a feeling the bearing will need to be changed as well. Its been leaking for a few weeks now. Probably took the grease out and cooked it. Its recently had a slight vibration/noise over 55 I was hoping it was new tires or the shop not balancing them correctly. Going to rotate the tires to see if it changes anything in the mean time.
Will need to get some more tools together for measuring end play and pulling race/seal out of the tube before I tackle the job. Think I can make something like whats used in the FSM out of steel to get the bearing and shaft apart.
1990 LWB RS A/T
1990 LWB Base A/T
Re: Rear axle leak [Re: danz91crx] #1077608 04/14/15 04:48 AM
H
haztoys Offline
No and no .........And no ...
Mitzu rearends dont die ..... They can .......But thats rare..Bad axle bears make noise 'all the way down to a stop.." ... Now driveshafts make noises at 55mph.. Is the rear driveshaft 'out of time' ...? .. Some years ago I chocked <img src="/forums/images/graemlins/frown.gif" alt="" />..Hit a rock in my Rally Truck and plucked the right rear tire off the truck ...As in we have three wheels on the truck ..One off in the weeds ..LOL.. Bent the rearend housing the spring and u-bolds ... Reused the axle shaft .. The axle has been pissing out the axle hole for years ... Its still going .. Installed two new seals repacked the axle bearing ... Its still pissing out the hole ..LOL ... Someday <img src="/forums/images/graemlins/rolleyes.gif" alt="" />.. I will install the new axle shaft I have .. Or not .. You got years on that axle bearing ... Grease or 90w gear oil its fine as long as it has some sort of lube .. 'End play' its a "feel" not a tool measurment.."Going to make a tool for axle bearing replacement" ... Good luck ..I have OEM Mitzu and Toyota and so on tools ...They dont work on AZ trucks ... Your in NYC rust .. Buy a oxy acetylene torch and a HF 20 ton press thats how the pros do it ...
Hope I'm not coming across as rude ...Not trying too..
Captain Gear Box
Hazardous Toys inc
Re: Rear axle leak [Re: haztoys] #1077609 04/14/15 06:41 AM
I'll rotate the drive shaft 180 degrees and see if its better.
I appreciate you sharing your experienced knowledge <img src="/forums/images/graemlins/kewl.gif" alt="" />
1990 LWB RS A/T
1990 LWB Base A/T
Re: Rear axle leak [Re: danz91crx] #1077610 04/15/15 02:27 AM
JohnnyBfromPeoria Offline
Agree with HazT, check your driveshaft "carefully" for any nicks or dents.
John B.
'95 Pajero Mini
'98 Montero Winter Ed.
'04 Cadillac XLR
'03 Kawasaki ZRX1200R
'60 Ford Falcon 4Dr
Re: Rear axle leak [Re: danz91crx] #1077611 04/17/15 10:14 AM
H
haztoys Offline
Thanks for listening .. I'm a 'mechanic' to pay the rent ... So to most people I'm a thief and don't know what hell I'm taking about ... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />..High JB..
Axle' bearings and 'diff' bearing make noise all the time .....Untill.............................They get loose enough that the 'ring-n-pinion' looses its 'setup' then you get a 'whine' at 40 to 70 ...Or.... As in my ALS Raider the factory spec sucks on rearend gears and my rearend has allways been set up 'off' from new and whines some ... But you can turn said whine on and off with on and off of the gas peddle ...Driveshafts vibrate at 50 to 60 you can feel it in you butt in the seat ..
Is the drive shaft bent.?... Lost a weight.?..Look for a 'spot weld' where the drive shaft spit a weight...Did you lift your truck and the u-joint angles' is all dicked up....?
Rear end and stick-shift trans work is a 'feel'...Big chunks if OEM FSM is FOS..
Pull the drive shaft and wheels and brake drums and 'grope' the rearend and 'feel' what you can 'see'... Take a good size hammer and give each axle shaft a good whack on the end.. Then feel the 'axle end play'...
Is this Greek ......?
Have a good day
Captain Gearbox
Hazardous Toys inc
Re: Rear axle leak [Re: haztoys] #1077612 04/17/15 05:10 PM
I did 180 the drive shaft to the pinion flange and the vibration is less.
Saw two weights on the shaft but and did not see clean spots. I'll look again to make sure nothing else fell off. Its not bent or dented.
Seems to me that after driving 15 mins or so I get more noise and slight vibration.
I do have a whine like you mentioned that comes and goes depending on throttle position. Most noticeable at 1/16-1/8 throttle when going 55-60. I'm at stock height as far as lifts.
Will take the wheels off and disco drive shaft to fumble with it properly when I can.
Have a car front end to rebuild this weekend for a relative (free) struts, calipers, hoses, control arms and ball joints. As long as it goes smoothly I should get to mine.
Maybe I'm wrong about the throttle. It may be more like a sweet spot when your coasting not accel or decel on flat road and noise/vibration goes away for a second.
1990 LWB RS A/T
1990 LWB Base A/T
PHP: 7.2.34 Page Time: 0.021s Queries: 16 (0.007s) Memory: 2.8919 MB (Peak: 3.1636 MB) Data Comp: Off Server Time: 2021-07-24 11:46:14 UTC
