by polar - 01/14/21 08:42 PM
by polar - 01/14/21 08:40 PM
torsion bar question
Vet over his Head
by tcb762 - 01/12/21 11:02 PM
by code33 - 01/03/21 03:52 AM
Vet over his Head
1 registered members (4Crawler), 102 guests, and 5 spiders.
Posts1,080,940
Thinking about swapping in a 1995 3.5L SOHC into my Gen I #1078092 05/16/15 02:05 AM
Jay Ayala Offline OP
Guys,
Does anyone know off hand of any other forum topics or members who have discussed this on the wire?
Re: Thinking about swapping in a 1995 3.5L SOHC into my Gen I [Re: Jay Ayala] #1078093 05/16/15 04:14 AM
J
jeepfreek Offline
http://www.mitsubishi-forums.com/t75137-6g-engine-series-questions.htm
This is as far as I got with the same question. You would have to upgrade to all the 3.5 controls.
Re: Thinking about swapping in a 1995 3.5L SOHC into my Gen I [Re: jeepfreek] #1078094 05/16/15 03:37 PM
4x4Wire Offline
The 4x4wire archives have some info on this topic:
http://www.4x4wire.com/forums/showf...mp;page=0&fpart=all&vc=1
Use the keywords 3.5l soho swap in the search box at the top of the page for additional info on the topic....
Re: Thinking about swapping in a 1995 3.5L SOHC into my Gen I [Re: 4x4Wire] #1078095 05/16/15 03:44 PM
JAVYPRO Offline
Oh men and my brother just told me of a guy selling a DOHC with tranny and all for $600 but in PR. That is a nice project.
I would jump on something like that only if I had more garage space.
Javy
Re: Thinking about swapping in a 1995 3.5L SOHC into my Gen I [Re: JAVYPRO] #1078096 05/16/15 05:09 PM
I thInk I made a mistake in the topic of the thread. I'm pretty sure the 1995 3.5L engine only came as a DOHC. I think it switched to SOHC in 1997.
Re: Thinking about swapping in a 1995 3.5L SOHC into my Gen I [Re: Jay Ayala] #1078097 05/16/15 07:51 PM
Mudraider Offline
You can edit that. Well, what vehicle are you contemplating doing that with? 6 cylinder? Relatively easy. Think about it, one object at a time. Less daunting that way. And I'm taking for granted that you have the donor vehicle handle, will certainly make the swap easier.
1. Engine Mounting. If yours is a V-6 it should bolt in. The engine mounts and the trans should bolt right up. Done
2. Exhaust. Probly won't match right off the bat. A simple combo of the two should get you to a muffler shop til you can do it right. A couple of feet off the 3.5 exhaust from the collector, cut a couple feet off your 3.0 exhaust, some flex pipe from any part store. Done.
3. Fuel. Here is where it gets interesting. Will the stock 3.0 work? Not researched that enough. Flow RAtes, Pressure, etc. If not, then figure out way to put a 3.5 one where the 3.0 one is. Then figure out how you will mate the 3.5 fuel to the 3.0 body fuel lines. Done.
4. Electrics. This is what kills it for most. Ususally over thought out though. ECU remove 3.0, put in 3.5. Wiring Harness. Seperate and remove 3.0 wiring harness. Label everything. Gauges wiring, battery hots, ignition hots, grounds. If you can have both side by side outside the engine compartment, this would go much easier. Have the 3.5 with it's harness still on, remove the 3.0 with it's harness complete. Then compare connections, figure out which are body connections and which are ECU connections. You can figure all that out while it is still outside the vehicle.
5. Accesories - air intake, power steering, AC. For starters, with an empty engine compartment, You should be able to mount that stuff in the original placement on the donor vehicle. Maybe have to drill some holes, etc. Done.
Not minimizing the swap as just an engine change, but it is much easier to contemplate. Leta ll that roll around a bit. One step at a time. And I'm sure others will come in and want to shoot this down. Instead, please feel free to add to it. If this Hyundai 3.5 deal works, this can open up an engine swap choice for the older models. Now if you have a 4 cyl, an addendum to the motor mounts is cutting off the 4 cyl mounts and moving them to allow the proper placement. And down the road; extra weights on torsion bars, weaker 4cyl axles.
Re: Thinking about swapping in a 1995 3.5L DOHC into my Gen I [Re: Mudraider] #1078098 05/17/15 02:42 PM
JohnnyBfromPeoria Offline
Pa_Jero did this already. Contact him!
It's a beast.
John B.
'04 Cadillac XLR
'03 Kawasaki ZRX1200R
Re: Thinking about swapping in a 1995 3.5L DOHC into my Gen I [Re: JohnnyBfromPeoria] #1078099 05/17/15 04:58 PM
Malykaii Offline
User SRTNATE had a build thread that never got finished. It has a lot of good info, I just don't know if he ever finished that project.
Re: Thinking about swapping in a 1995 3.5L DOHC into my Gen I [Re: Malykaii] #1078100 05/17/15 05:33 PM
TOASTY Offline
X2 JBFP, we put 3.5 DOHC in PA_JERO's 4cyl gen 1 and that thing is awesome! So glad we did that. It'll go easier in a truck originally equipped with a V6.
1999 Montero Blizzard package
1991 Montero RS
Re: Thinking about swapping in a 1995 3.5L DOHC into my Gen I [Re: TOASTY] #1078101 05/17/15 08:24 PM
TOASTY,
Was it just the engine? Or the entire powertrain?
PHP: 7.2.34 Page Time: 0.026s Queries: 16 (0.009s) Memory: 2.8970 MB (Peak: 3.1638 MB) Data Comp: Off Server Time: 2021-01-15 21:46:57 UTC
