Gordie the Galloper?
Is Pajero Same as Galloper?
Smoking winch
Smoking winch
Power steering pump leak.
replace master cylinder
0 registered members (), 108 guests, and 5 spiders.
Topics138,202
Posts1,081,253
A/C gone! #1078148 05/22/15 12:23 AM
hacker Offline OP
A/C only blows warm air although the engine changes idle speed when the a/c is turned on so I'm assuming the compressor is trying to work.
After the a/c ran for 10 min both lines leading from the compressor were warm.
Next step I suppose would be to check a/c system pressurization. My experience with a/c systems losing pressure in the past resulted in a slow loss of cool air where it gets less and less cool until the air finally isn't cool at all...which coincides with the 'freon' slowly leaking out. Since this happened all at once should I assume there's a major leak somewhere and should do some kind of system pressurization test before I dump more freon in? Or should I be looking somewhere else in addition to checking freon?
~~_/) ~~
www.maps.org
Re: A/C gone! [Re: hacker] #1078149 05/23/15 04:34 PM
4x4Wire Offline
You are on the right track.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: A/C gone! [Re: 4x4Wire] #1078150 06/11/15 09:17 AM
hacker Offline OP
With the intention of using the gauge I got a can of refrigerant from the local parts store and hooked it up (separate from the bottle). Although before I assumed I had a leak, turns out my system appears to be OVER pressurized instead of under. Not sure how that happens at all. Also, my serpentine belt just started to squeak. Never has before and seems tight, so dunno maybe the two problems are related.
With this new info in mind is there any advice on where I should look now for the problem?
~~_/) ~~
www.maps.org
Re: A/C gone! [Re: hacker] #1078151 06/11/15 02:57 PM
Jim_Paget Offline
If the belt has started to seriously squeal, your A/C compressor clutch may have given up the ghost. Turn on the A/C and look at the compressor to see if the belt is turning the compressor. If not, the clutch is probably toast.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: A/C gone! [Re: Jim_Paget] #1078152 06/12/15 10:06 AM
hacker Offline OP
Good news looks like I may have narrowed down the problem. Turned the a/c on and observed the inner wheel of the compressor to be totally stationary for the 15 minutes I watched it. And the new squeak I'm hearing seems to be coming directly from the compressor.
Is this enough info to give a definite diagnosis of a bad compressor clutch, or could it still possibly be something else?
~~_/) ~~
www.maps.org
Re: A/C gone! [Re: hacker] #1078153 06/16/15 01:25 AM
hacker Offline OP
bump
~~_/) ~~
www.maps.org
Moderated by  4x4Wire
PHP: 7.2.34 Page Time: 0.027s Queries: 15 (0.008s) Memory: 2.8462 MB (Peak: 3.1632 MB) Data Comp: Off Server Time: 2021-04-14 20:52:02 UTC
