85
Topics138,201
Posts1,081,246
Which Alternator?
#1078167
05/22/15 05:51 PM
Read the archive about upgraded alt's for Gen 1 SWB here Seems to be some discrepancy. Any advice on what to get, or just go with a Starion unit?
--Tres (John 14:6)
Black 87' Raider 2.6L/Webber 88 5 Speed Welded front,tight LSD in the rear Removed bump stops 4'x6' roof rack 10k. Lb. winch on receiver hitch/custom bumper 100 amp alt CB radio/AC inverter S.Winch hubs Enormous RV battery
Re: Which Alternator?
[Re: TresMon]
#1078168
05/23/15 04:29 PM
If you get a starion unit used, it won't likely last. Guys on starquestclub report many issues. If you get it new, there are,many better options for that money. http://m.ebay.com/itm/121324436893?nav=SEARCHThat's a Hyundai elantra alternator designed to bolt right in. Only heard good stuff, have one on the shelf to,drop,in next weekend. http://m.ebay.com/itm/171686085776?nav=SEARCHThere was a group buy on starquestclub years ago before my time. Its a adaptor kit to use a gm "iceberg" alternator. You can get up to 135 amps. The above is just an example, the seller has is in la la land with that price. More like $100.
[Re: Malykaii]
#1078169
05/25/15 02:26 PM
Thanks! What year and motor of Elantra? I dont do Ebay. Wanna look it up on RockAuto.com.
Thanks again!
--Tres (John 14:6)
[Re: TresMon]
#1078170
05/26/15 02:34 AM
Sorry, I wasn't being clear on that. There's an alt/starter shop in cali making these things. I don't know the details, but from the looks it's a Hyundai elantra alternator case modified to fit the g54b along with a starion pulley. Internals are maybe elantra with a mitsu voltage regulator or something.
Its home brew, so you can only get it from them or make your own.
[Re: Struc]
#1078172
06/01/15 03:08 AM
Thanks everyone.
The modded Elantra alt should arrive this week.
--Tres (John 14:6)
