Replacement MAF unit .. Gen1
Gen1 cigarette lighter port.
GEN I Auto hubs
by polar - 02/16/21 06:55 PM
by polar - 02/16/21 03:03 AM
GEN I Auto hubs
0 registered members (), 120 guests, and 3 spiders.
Topics138,176
Posts1,081,000
!987 Dodge Raider Half shaft assembly removal ? #1063218 08/24/13 11:11 AM
H
huntnsonvagun Offline OP
The passenger side inner axle knuckle is shot Im going to replace the whole half shaft assembly, this looks pretty easy but I thought I would try and get some tips from someone that knows do you have to remove control arms to get the drive axle out or can you just unbolt the inner part of the shaft and pop the outer axle knuckle out of the hub..... thanks for any feedback <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: 1987 Dodge Raider Half shaft assembly removal ? [Re: huntnsonvagun] #1063219 08/24/13 04:29 PM
The right side inner CV unbolts from the drive front axle assm. There is a retaining clip on the outside CV. I have successfully removed this piece by:
1. Disassemble the Auto Hub / Manual 4wd hub and remove.
2. Remove CV c-clip.
3. Remove 4 nuts & washers from the inner CV. The bolts will remain attached to the adapter.
4. Compress the CV shaft and pull down and out toward the front of the vehicle.
Two things more: 1. the vehicle must be lifted and stable for this work, 2. I have never re-installed a shaft by this method...as I generally only pull parts from the parts cars.
Russell
Re: 1987 Dodge Raider Half shaft assembly removal ? [Re: huntnsonvagun] #1079144 09/29/15 04:03 PM
8
87dodgeraider Offline
any help or tutorials on removing and reinstalling the front driver side half shaft? from looking at the vehicle, the driver side is different from the passenger side
1987 Dodge Raider
Re: 1987 Dodge Raider Half shaft assembly removal ? [Re: 87dodgeraider] #1079146 09/29/15 04:33 PM
danz91crx Offline
Should be a circlip behind the differential cover that comes off before the LH shaft can be removed. You can find diagrams and instruction in the factory service manual available at mitsubishilinks
1990 LWB RS A/T
1990 LWB Base A/T
Re: 1987 Dodge Raider Half shaft assembly removal ? [Re: huntnsonvagun] #1079159 09/30/15 06:10 PM
off-roader Offline
BTW, do you have the FSM for the 87? It's on mitsubishilinks.com if you need it. It should have a pretty decent outline of the r&r process.
Off Roader
96SR (3.15:1 xcase, 35's)
96SR Build Up Thread
Old web page
Old web page
Re: 1987 Dodge Raider Half shaft assembly removal ? [Re: danz91crx] #1079168 10/01/15 06:18 AM
danz91crx Offline
My mistake, you can remove them with force apparently and don't need to take the diff cover off.
1990 LWB RS A/T
1990 LWB Base A/T
PHP: 7.2.34 Page Time: 0.026s Queries: 15 (0.008s) Memory: 2.8474 MB (Peak: 3.1638 MB) Data Comp: Off Server Time: 2021-02-25 19:52:44 UTC
