99
guests, and 3
Topics138,206
Posts1,081,272
Re: EURO, ***** & USA CAPS
[Re: OldColt]
#904357
03/11/09 04:20 PM
I haven't tried it but perhaps you could simply install a Europe instance of wincaps under c:/WincapsEur and the Japan wincaps under c:/WincapsJap, etc. Then change the configuration/setup screen for each instance to look for the data set in the corresponding directory. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: off-roader]
#904358
03/11/09 05:00 PM
That sounds like the way. I have put each dataset in a separate folder in the wincaps directory. I guess a manual entry in setup to link each but am curious if there is a way to toggle directories such as with the F keys. I seem to be getting weaker in my DOS setups.
Cheers, Charlie If It ain't broke, Modify it! 87 Montero turbo Converted back in Spring1989 95 Montero SR 3.8 DOHC Only one? 93 Pajero 3 door 6G75 Mivec with paddle shifted 5 speed Then a Gen2 SR with full coil independent suspension.
[Re: OldColt]
#904359
03/11/09 05:06 PM
Ahh, I think I might have it, the F8 key is CD switch.
[Re: OldColt]
#904360
03/11/09 05:17 PM
Outstanding Red Team! I will try all this as well. Assuming I can repeat across them, I'll look to add a ReadMe to the ZIPs I have posted up. May take me a few to get to it...
[Re: MontyMcV]
#904361
03/11/09 05:38 PM
I almost have it, i copy and pasted the path to each file, Caps did not seem to want the final directory included as it's original path shows. When I toggle I do get a different list of cars but I do get an error message about loading the CD. So I am close but not there yet. ![[Linked Image]](http://www.vermontel.net/~dcma/Caps1.jpg)
[Re: MontyMcV]
#904362
03/12/09 06:58 PM
Oh boy I did it now, Yesterday I had caps switching between data sets but not fully opening the other sets. It gave me the list of car lines but I could not get any further. Well today, I just opened Wincaps and it opened in Japenese. Humm, so I opened the setup, easy since it is the bottom of the file column. Fine but it gives me a different selection and all in ???????. It will not convert languages. I guess I will be a bit delayed in getting todays parts order called in.
[Re: TOASTY]
#1079316
10/16/15 03:46 AM
apparently doesnt work with 64x windows, working on fix
94 montero SR 3.5. 33" BFG TA KO's, OME HD rear springs, front T-bar crank. 93 600 Katana. stage 1 jet kit, Uni foam air filter 02 honda shadow. "for when the woman wants to go with" 97 Acura Integra.
[Re: mynion]
#1079319
10/16/15 05:19 AM
ASA Version 1.3.0.2 working fine on windows 7 x64 for me
1990 LWB RS A/T 1990 LWB Base A/T 1991 LWB LS A/T Going...Going...
Re: EURO, Japan & USA CAPS
[Re: TOASTY]
#1104302
04/29/18 01:58 AM
Hi All, Is the Mitsubishi CAPS/ASA program still available? I cannot seem to get any of the downloads or links to work?
