by rascott - 01/26/21 02:26 AM
by B_Line - 01/21/21 04:16 PM
by polar - 01/14/21 08:40 PM
torsion bar question
Vet over his Head
by polar - 01/14/21 08:42 PM
by tcb762 - 01/12/21 11:02 PM
by code33 - 01/03/21 03:52 AM
Vet over his Head
0 registered members (), 77 guests, and 3 spiders.
Posts1,080,942
Need TPS help #1079320 10/16/15 12:17 PM
3
357transam Offline OP
Well, I haven't been on the forum here for quite a while. Still have the Sportage. Still have been modding, wheeling, and whatnot.
The issue I have, is that for the last several years, I have been fighting an SES. Fault code P0506.
I have replaced nearly all the sensors in the vehicle, up to and including the TPS, MAP, MAF, Chassis Acceleration Sensor, PCM, EGR valve and solenoid, and any and all vacuum lines I could find. I have back probed, disconnected, and ohm checked the entire engine harness.
The only thing that I continually get is a bad TPS signal. The sensor is receiving the proper 5v signal, and there is 0ohms of resistance on the ground side to the pcm. The sensor input to the pcm, however, will only send back .287 V when the throttle is closed. This leads me to believe that the new TPS is faulty.
So what I need is this: will someone with a properly functioning sportage check resistance between pins 2 and 3 on the TPS and record their findings? Please, before I say screw it to this motor and go for a 5.3 swap?
Re: Need TPS help [Re: 357transam] #1079403 10/28/15 01:14 PM
3
Bump? Nobody?
Re: Need TPS help [Re: 357transam] #1079428 11/04/15 01:40 PM
10ring Offline
Isn't there a speed sensor in/on the transmission?
My engine bay is in pieces, so the next time I'm banging on it, I can get a reading for you on my new (less than 600 miles) TPS.
Can you explain a bit more what you need me to measure and where?
Re: Need TPS help [Re: 10ring] #1079429 11/04/15 06:41 PM
3
Thanks for the response! Off the top of my head, the vehicle speed sensor is in the transfer case I think.
As for the TPS, I just need a resistance reading across pins 2 and 3 of the sensor. For my 97, pin 2 would be green/yellow, pin 3 is yellow black. According to all data, fully closed the sensor should have 1k ohms, and fully open it should have 2.4k ohms.
The issue is, both the original tps, and the new one I purchased read differently than that spec.
PHP: 7.2.34 Page Time: 0.026s Queries: 15 (0.008s) Memory: 2.8338 MB (Peak: 3.1636 MB) Data Comp: Off Server Time: 2021-01-26 06:52:00 UTC
