Battery light - what's it telling me?
by GrantCee. 07/14/18 10:27 PM
'87 Montero clear coat flaking
by GrantCee. 07/12/18 12:32 AM
Echo
by rxinhed. 07/11/18 02:22 AM
by rxinhed. 07/11/18 02:21 AM
1989 GEN 1 3.0L Oil Pressure
by DRLExpress. 07/05/18 08:41 PM
GEN1 LWB Radio reception
by chadzeilenga. 07/04/18 05:46 AM
Need Help - SOHC Valve Adjuster Replace
by tdf46. 07/03/18 01:38 PM
by tdf46. 07/03/18 02:02 AM
Bouncy seat
by montero1970. 07/01/18 06:57 PM
The slow rebuild thread
by DRTDEVL. 06/30/18 03:28 PM
Scratch my last post... wow!
by DRTDEVL. 06/28/18 02:08 PM
My '88
4x4Wire YJ
0 registered members (), 109 guests, and 6 spiders.
Topics137,890
Posts1,079,529
Members14,783
Page 2 of 2 1 2
Re: Help - 1990 Gen 1 not starting, stranded [Re: huggie] #1079408
10/29/15 07:08 PM
10/29/15 07:08 PM
cheesegrater  Offline
Franklin IN
Turn your headlights on and try to start. if lights stay bright, no juice is going to starter (an open circuit). if lights dim, bad starter. if lights go out, bad battery.
Re: Help - 1990 Gen 1 not starting, stranded [Re: huggie] #1079411
10/30/15 06:35 AM
10/30/15 06:35 AM
huggie  Offline OP
California
Yup, starter is toast. I love this dang ugly forum. smile
Re: Help - 1990 Gen 1 not starting, stranded [Re: huggie] #1079457
11/09/15 07:51 PM
11/09/15 07:51 PM
fasteddy  Offline
Helen , GA *****
I personally feel able to start the truck safely without the "aid" of an inhibitor switch. You do put a foot on the brake while cranking, right?
Re: Help - 1990 Gen 1 not starting, stranded [Re: huggie] #1079569
11/12/15 07:05 AM
11/12/15 07:05 AM
Leopard14  Offline
Houston, Texas
I realize you have probably done this. But, I had similar problems and was getting ready to tear apart the starter and soleniod, after having cleaned the inhibitor switch and changed out the ignition switch cable. It ended up being the connectors attached to the positive terminal. A little sanding of both the terminal(there was rust on the metal) and of the wire connector and it turns on every time.
Re: Help - 1990 Gen 1 not starting, stranded [Re: Leopard14] #1079570
11/12/15 07:31 PM
11/12/15 07:31 PM
fasteddy  Offline
Helen , GA *****
starter solenoid most likely. The solenoid is clicking when you engage start. The copper disc on the forward end of the solenoid is not making contact across the two big terminals to which batt and starter are connected. Probable cause is accumulated arc scars. Sometimes you can whack the starter solenoid with a hammer while start is engaged at key, and you'll get a connect. You can also repeatedly hit start and the repeated hammering of the solenoid core will do the same. You can also pull the starter and remove solenoid and pull the core and sand off the copper disc.
Most starter "failures" are just like this, and most "rebuilt" starters are rebuilt just this way, or with only a new solenoid.
Starter diagnosis 101:
Tests are easiest out of the truck, but you can do them all in situ, just a good chance of arcing/welding stuff.
There are 3 terminals on the starter. One (S) is a small spade that carries ign power to the starter in start position. One (B) is a large copper lug with the heavy batt wire attached. The third (M) is an identical copper lug with a wire/strap connected to the motor windings.
Using jumper cables, connect batt neg to starter frame. connect othercable to batt pos, and touch to terminal M. Good motor will run without gear extending. Now touch batt+ wire to terminal S. Solenoid will click, gear will extend, motor will not run. Now connect batt+ cable to terminal B. This is the normal state of the installed starter. Using a jumper wire, connect B to S. Solenoid should extend, then motor should run IN THAT ORDER. If the motor does not run, it's the solenoid copper disc, or crud in the solenoid is blocking the full motion of the core.
Page 2 of 2 1 2
Page Time: 0.011s Queries: 16 (0.004s) Memory: 1.0205 MB (Peak: 1.1177 MB) Zlib disabled. Server Time: 2018-07-16 16:39:49 UTC
